Servis box blade
/ Servis box blade #2
/ Servis box blade
WOULD BUY IF NOT OUTRAGUS LOCAL DEALER SAID THEY COULD GET THEM FOR $100.00 EACH
/ Servis box blade #5
I think the rippers would be fairly easy to make with an O/A torch, and a large angle grinder, just make a pattern, torch out the shapes, and grind until perfect. $100 sounds like alot per ripper, are you sure they meant $100 PER TOOTH?
/ Servis box blade #6
When I built my ripper / counterweight I bought the shanks from Agri-Supply. Back then they were about $9.00 a piece.
Agri Supply - Search
/ Servis box blade #7
I built a makeshift tooth bar for my back blade out of Railroad Spikes. Rippers a different but Spikes could be engineered at an angle to do a fair job on a box scraper too. Plus they are usually Free and very hard.
/ Servis box blade #8
What does the teeth look like? Do they have holes in center or notches in front or back? Teeth are available for less than the price you where quoted, the types I mentioned are about 20-30 bucks each and come in different lengths( regular or long)
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
1988 Yamaha 200hp 2-Stroke Boat Motor (A66738)
1988 Yamaha 200hp...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
2016 MAGNUM  MLT6S (A68842)
2016 MAGNUM MLT6S...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
