Servis box blade
/ Servis box blade #2
/ Servis box blade
WOULD BUY IF NOT OUTRAGUS LOCAL DEALER SAID THEY COULD GET THEM FOR $100.00 EACH
/ Servis box blade #5
I think the rippers would be fairly easy to make with an O/A torch, and a large angle grinder, just make a pattern, torch out the shapes, and grind until perfect. $100 sounds like alot per ripper, are you sure they meant $100 PER TOOTH?
/ Servis box blade #6
When I built my ripper / counterweight I bought the shanks from Agri-Supply. Back then they were about $9.00 a piece.
Agri Supply - Search
/ Servis box blade #7
I built a makeshift tooth bar for my back blade out of Railroad Spikes. Rippers a different but Spikes could be engineered at an angle to do a fair job on a box scraper too. Plus they are usually Free and very hard.
/ Servis box blade #8
What does the teeth look like? Do they have holes in center or notches in front or back? Teeth are available for less than the price you where quoted, the types I mentioned are about 20-30 bucks each and come in different lengths( regular or long)
2013 PETERBILT 367 FLATTOP SLEEPER TRUCK (A67714)
2013 PETERBILT 367...
KUBOTA ZD1511 ZERO TURN LAWN MOWER (A65057)
KUBOTA ZD1511 ZERO...
x (A68191)
x (A68191)
2013 Toyota Tundra Crew Cab Pickup Truck (A66736)
2013 Toyota Tundra...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2018 MAGUNS  VACUUM/POWER WASHER TRAILER (A67714)
2018 MAGUNS...
