Servicing manual steering
/ Servicing manual steering #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
As part of my weekend "what can I check on my tractor" schedule. I remembered to check the steering oil. Well I don't think there was any in there. After locating the standard 3/8" square plug (painted red at once), and removing that sucker 1 degree at a time (I needed a 3" wrench or remove another bracket), I filled and filled with oil. I figured I'd just need a top off so I didn't look at the bottle. I must have put in at least 6-8 ozs, It was dry. Still steers about the same but it's got some lube in it now. I used standard 80-90w gear oil. You can see the red plug just in front of the hose.
And of course a pic for you!
2019 CATERPILLAR 246D3 SKID STEER (A62129)
2019 CATERPILLAR...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
Wooden Wagon Wheel Bench (A61569)
Wooden Wagon Wheel...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
