Server or site problems.
/ Server or site problems. #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
Am I having problems with my server or is it problems with the site. I click on a topic when I go to the Since My Last Visit area, and it takes for ever to load today. I'm not having problems with other sites so I don't think it's a server problem. Am I the only one?
/ Server or site problems. #2
Been here quite a bit today--had a day off--and encountered no problems. I also do the Since my Last Visit, and it has worked fine.
Regards, Mike
/ Server or site problems. #3
One way to determine if it is TBN servers or something else, is to look at the line of text at the bottom of each page. Load at the load time. If it shows a few seconds or up to 5 or 10 seconds, or longer, it may be our servers experiencing a problem. If it is very quick, like less than a second, the problem is likely with the overall Internet pipes, or your local provider.
Here is the number from loading this page just now:
"Page generated in 0.77432 seconds with 15 queries"
It appears on this morning, that your issues are most likely with your provider, and not the TBN servers. No one else has reported problems today.
Hope you get it worked out. :(
/ Server or site problems. #4
I used to have a problem like that. Page seemed to take forever to load. It took longer than dial up. It turned out my computer had a lot of spyware that wasn't caught by the filters. I went to a couple of sites someone else posted here and got a spyware blaster program and CCleaner program that I run every day to keep the computer cleaned up. My data said this page was generated in .54712 seconds with 11 replies. Also make sure your antivirus and anti spam programs are up to date.
Well it's still slow today. When I click on the google site it loads right away. I went to send this message and this is what happened.
The top header of the page loaded right away. It then took 3o seconds for the body of the page to load. Then from the Post Reply message it took anouther 55 seconds to load.
The message at the bottom said it loaded in.27178 sec. with ii quries.
I left the site and went to my state DEC site ( a lot of graphics) It loaded up imediately. I checked for spyware and found none.
It is slower than dial up.
/ Server or site problems. #7
Personally, I'm a computer dummy, so I have no idea what the problem could be, but it's running normal speed for me.
/ Server or site problems. #8
Sorry, Paul, I can not help either. I am not having any TBN performance issues.
/ Server or site problems. #10
Paul,
I'm afraid it's something that's outside of our control. It's clearly not a server issue as the pages themselves are generating in less than a second. So it's not bottle-necking there.
This is the nature of the Internet. The path your computer takes to get to our server is clearly not very efficient. I doubt that it's on our server's connection's end as that would reflect in other people would experience the problem. It might not be on your end, either. But it might be someplace in the middle.
There is very little I can do except ask you to go Start->Run->"cmd" then hit ok. When the DOS box pops up, type: tracert tractorbynet.com
Then paste in a reply what the results are.
-Ibrahim
/ Server or site problems. #11
Here's what I get here in Indiana....
C:\>tracert tractorbynet.com
Tracing route to tractorbynet.com [208.100.11.68]
over a maximum of 30 hops:
1 141 ms 99 ms 80 ms webserv.imcuniverse.com [208.100.11.68]
Trace complete.
C:\>
Mine shows 9 different entries today. Its another slow day. Yesterday was fine.
/ Server or site problems. #13
Not knowing your experience with tracert, I kinda doubt Mossroad is only one hop away from TBN, I believe he just cut and pasted the last entry, right Mossroad?
Toadhill - what do the times look like on a fast day?
I'm on a DSL line and the times on a good day are within seconds, usually 2 or 3. On a bad day the header loads right away and the rest of the page takes as much as 1.5 minutes.
The strange part is when I load up the site the opening page loada well, I log in and the next page loads well. I click on a heading and the opening page loads well.
Then the trouble starts when I click on a specific topic. As I said before the header loads right away and then everything go's into slow motion.
The last line on the tracert inquiry reads
9 65ms 67ms 62ms webserv.imcuniverse.con(208.100.11.68)
/ Server or site problems. #17
What browser do you use?
My son in law set this computer up but I think used mosella firefox.
/ Server or site problems. #19
I need ALL the text that tracert shows. Not just the last line, please. :)
-Ibrahim
/ Server or site problems. #20
No. That's exactly what I get on my desktop at work. The firewall won't tell desktops any information inside our building. They don't need to know. :D
I get 10 hops from home, but don't want to publish that info. ;)
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A69167)
2005 MACK CXN613...
2019 CATERPILLAR 259D SKID STEER (A65056)
2019 CATERPILLAR...
40 YD ROLL OFF DUMPSTER (A67714)
40 YD ROLL OFF...
PORTA POTTY (A68842)
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2016 John Deere 1200H Bunker Rake (A66734)
2016 John Deere...
