Septic Tank Chemistry
/ Septic Tank Chemistry #1
Piperflyer
USA
Kubota3030HST
I keep seeing commercals for septic tank additives to promote a cleaner tank, if there is such a thing. Are these really necessary or should you let the tank work by it self? Any chemists out there.....
/ Septic Tank Chemistry #2
I would like to hear the answer to this from an expert as well
/ Septic Tank Chemistry #3
Not an expert but: From what I understand you don't need any thing added unless your good bacteria and microbes are damaged. Dumping too many phosphates, kitchen grease, bleach etc, down your drains.
/ Septic Tank Chemistry #4
I had out tank pumped around 6 weeks ago. I asked the owner of the septic service the same general question. He told me to flush 2 tablespoons of powdered yeast down the toilet once a month. He had been in business for 28 years. He also added that I should not allow food scraps, grease; etc. to enter the system.
/ Septic Tank Chemistry #5
IMO,
The worst thing for a septic tank type of system is chemicals. Bleach is the worst, bleach kills basically every living organism known to man, bleach in your septic kills bacteria, killing bacteria is killing billions and billions and billions of little soldiers whom do nothing all day long but eat each other!
Anti bacterial Soaps, do the same thing. The inside of your sewer and drainage system turns into slime, aliens, gook, youck and it eventually turns to as hard as lightweight concrete. Not all drains can be cabled because of this.
There is a product called BIO CLEAN
Bio Clean is basically good bacteria, you can put it in your mouth and it will not hurt you. I will let the web site I linked to do the selling, if your not convinced call them and ask questions.
I have been selling bio Clean for almost 12 years and no complaints. It is not smoke and mirrors, it can work, but you must STOP the chemicals. If I were to buy an older home I think the first thing I would do is pump the tank and scrap it inside and fill it w/ a fire hose, squiring it clean and pump it and do it AGAIN till I had it as clean as I can, I would put in maybe 300 gallons of as warm of water as I could and dump a few cans of Bio Clean in it and stir...BELIEVE IT.
/ Septic Tank Chemistry #6
As Artisan says, it works. I took over my father-in-laws Bio-Clean sales 30 years ago. He had sold it for probably 30 before that. It has a money back if you are not happy policy. He never paid back a claim, To date I have not either. I use it in my tank. The biggest mistake with it is using too much. It grows once put in use. The warm water method has worked the best for me.
/ Septic Tank Chemistry #7
The solids are supposed to stay in the tank, where they can be pumped out and disposed of as septage. If the solids get into the drain field, they will plug it solid and you will end up installing a whole new system. Adding bacteria won't hurt anything, but it won't help either.
Avoid grease and oils, which do not digest, and form the heavy crust on top of the liquid.
It's critical that the baffles are in good shape. The inlet baffles kill the momentum of sewage entering the tank, while the exit baffles skim the grease off the top and only allow liquids into the drain field.
How long your tank can go between pumping depends on what you put into it. Some plants have a high silica content, and leave a lot of sludge. Food scraps don't digest well, though there are garbage disposals with enzyme reservoirs designed to help that along. Smaller tanks or tanks with heavier usage will need to be pumped more often.
Avoid using a septic tank as an RV dump station. The RV chemicals will harm it, and the massive rush of water will overwhelm the baffles. For a similar reason, low flush toilets and front loading washing machines are a good idea. The less water you push through a septic tank, the longer the solids get to settle out.
Some people will brag about how long they have gone without pumping their septic tank. That works fine until it doesn't, and they end up buying a whole new system.
/ Septic Tank Chemistry #9
I have been told by septic tank people and plumbers, "yeah, it's great" or "waste of money". We don't use any and have the tank pumped every three years.
They were all pretty consistent about recommending against detergents etc., but what are you going to do?
/ Septic Tank Chemistry #12
as has been said. the biological ballance is the key in the tank.
greases cause issues, adn cleaning chemicals REALLY cause issues.
soundguy
/ Septic Tank Chemistry #13
I'd think of is more as Septic Tank Biology, as that will put you more in the spirit of what is happening.
/ Septic Tank Chemistry #14
I was told buttermilk is great for spetics.. this was tolkd to me by the husband and wife team that pumped our tank.. I would trust them she worked at a municpality waste plant for years.. I will say it was quite funny have a woman pump out our tank. :laughing:
/ Septic Tank Chemistry #15
I took waste water classes in college.
There really are no chemicals you should add or anything to a good system. Ideally you route both the clothes washer and dish washer around the septic tank. Even bath water, this would be called around here a grey water bypass. This grey water goes to a small box to catch small solids then to the leach field where both the grey water and overflow from the spetic go. Most people don't go this route due to cost. Try and avoid as others have stated soaps, cleaners and bleach. These kill the bacteria that will eat and break down the solids. My dad did put in a grey water system and has been able to extend his tank pumping to 8-9 years. People that run everything into one usually go 2-3 years.
As far as adding bacteria to a system, the system will only support what it can. IMO the things you add are a waste of money. If you have a lot of chemicals going down the drain, maybe they help, I doubt it though.
Everytime the tank is pumped make sure they check you baffles. As was stated it keeps the leach system from getting solids.
Here is site that seems to explain a lot. Seems most of the america web sites promote reuse of the grey water now.
Septic tank systems — Bio-Systems SA
/ Septic Tank Chemistry #16
My comments in RED
All tanks come with baffles yes? Not fail safe but should prevent this.
It won't help a system that has been chemicaled or flooded? Please tell me more. If I am in err I really need to know.
If I remember right, Bio Clean turns grease into a couple of different harmless compounds.
snip
BINGO, does not Bio Clean have said enzymes?
I would mention BLEACH kills your tanks digestive process, yes? therefore one w/ a septic tank should NOT use Bleach.
Indeed when it comes to plumbing, nothing lasts forever. It is amazing how many of my clients over the years always seem to come off w/ the comment;" We have lived here "X" years and never had a problem! " Eventually every last piece of pipe in a cast iron and galvanaized waste and vent system will need to be replaced. Newer plastic systems, when installed correctly, with clean outs everywhere, and hydrojetted at least every 5 years, will outlive our childrens great grand children, SEPTIC TANKS, moreso their drainfields, will all fail eventually, you have to service them from time to time weather they need it or not.
Next tuesday I go back to a restaurant, just a sandwich shop, no Preventitive Maintenence (PM) cabling or jetting over the years, they have been pouring BLEACH down the drain, IT IS SO FREAKING BAD FOR YOUR DRAINS, DO NOT DO IT, STOP IT IMEDIATLY AS WELL AS ALL CAUSTIC MIRACLE LIQUID DRAIN CLEANERS! LOL, your asking for much bigger problems. She spent 475.00 adding a 2" clean out and cabling, none o fteh trap primers are working, I go back Tuesday, she will be lucky if her bill is under 2K for me just to get "some" portions of the system to par. If you don't do PM plumbing work expect big problems.
/ Septic Tank Chemistry #18
"Not everyone agrees on the effectiveness of additives."
I want to be clear, if you don't pump chemicals into your septic, if your good to it and do not flood it or fill it w/ trash and food particles DO NOTHING.
If you have concerns, I would use Bio Clean "." . I think that is the jest of what the original poster is after in opinion.
Here is another septic "guide", from the EPA.
I see many a company producing their own manuals, and they are usually slanted towards trying to get you to buy there widget.
/ Septic Tank Chemistry #19
The tank itself is not the problem when it comes to failed systems. Usually the problem is a result of not getting your tank pumped out often enough. When this happens the floating scum layer will get pushed by the baffles that are intended and down into the field, coating it with an inpenetrable layer. By having the tank regularly pumped you not only removing the inert scum buildup, you are also allowing the field to "rest" and re-aerate.
Some good points are pointed out in the above posts and here are a few more; a garbage disposal is counted as a full bath and is a major factor when designing the septic system... liquid soaps are generally a little better for your system than bar soaps, bar soaps often use fats as solidfiers... and finally a simple upgrade to some older systems is to add a vent at the far end of the field (the candycanes you often see). This vent in combination with your roof vents will allow a LOT more oxygen to be drawn in for the beneficial bacteria to use in breaking down the organics.
Here is a really good site for learning about modern septic systems; Septic System | Leach Field | Onsite Wastewater Treatment | Presby Environmental
/ Septic Tank Chemistry #20
I've built three places in country w/septic systems. I am in the camp that believes you don't use a garbage disposal, instead get a dog or dump grease and scraps in the woods for the coon. You unhook the washer from the system after inspection, and don't put nothing down the crapper that you didn't eat first. I got zero problems.
