Piperflyer
I keep seeing commercals for septic tank additives to promote a cleaner tank, if there is such a thing. Are these really necessary or should you let the tank work by it self? Any chemists out there.....
Fixed the links abovehttp://www.shelterpub.com/_shelter/ssom_additives.html/
Information on additives.
Your Septic System | CMHC
Information on septic systems.:thumbsup:
The solids are supposed to stay in the tank, where they can be pumped out and disposed of as septage. If the solids get into the drain field, they will plug it solid and you will end up installing a whole new system.
All tanks come with baffles yes? Not fail safe but should prevent this.
Adding bacteria won't hurt anything, but it won't help either.
It won't help a system that has been chemicaled or flooded? Please tell me more. If I am in err I really need to know.
Avoid grease and oils, which do not digest, and form the heavy crust on top of the liquid.
If I remember right, Bio Clean turns grease into a couple of different harmless compounds.
snip
How long your tank can go between pumping depends on what you put into it. Some plants have a high silica content, and leave a lot of sludge. Food scraps don't digest well, though there are garbage disposals with enzyme reservoirs designed to help that along. Smaller tanks or tanks with heavier usage will need to be pumped more often.
BINGO, does not Bio Clean have said enzymes?
Avoid using a septic tank as an RV dump station. The RV chemicals will harm it, and the massive rush of water will overwhelm the baffles. For a similar reason, low flush toilets and front loading washing machines are a good idea. The less water you push through a septic tank, the longer the solids get to settle out.
I would mention BLEACH kills your tanks digestive process, yes? therefore one w/ a septic tank should NOT use Bleach.
Some people will brag about how long they have gone without pumping their septic tank. That works fine until it doesn't, and they end up buying a whole new system.
