Grapple Selector Valve for Grapple problem
/ Selector Valve for Grapple problem #1
kernal
Rochester NY
JD 2320
Ok, I finished installing and wiring the selector valve kit I got from WR Long. Start the tractor, hold the button grapple opens, closes, I was very happy. Release button, operate the FEL to make sure everything works, it does. Here is the issue, after using the regular function, holding the button no longer works. Voltage to the valve is still good. I have no idea why after using the main fuction the divertor stops working.
Any help is greatly apprciated. If I don't get it resolved I'll be calling WR Long in the am.
Scott
Where's moron, here I am.
When finding a power source, use a meter not a test light as the light will not tell you the wire is 6 volts and not 12 volts.......
The selector valve now works great. I do think that I will do as Kennyd did and install a relay with a lead directy to the battery for the valve.
/ Selector Valve for Grapple problem #3
Glad you got it fixed:D
Let me know if you need help with the relay...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2006 KENWORTH  CAB & CHASSIS (A67714)
2006 KENWORTH CAB...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
CAT 966D Grapple / Bucket (A68134)
CAT 966D Grapple /...
2015 Evinrude G-2 250hp Outboard Boat Motor (A66738)
2015 Evinrude G-2...
2020 Bobcat T650 Compact Track Loader Skid Steer (A66734)
2020 Bobcat T650...
