Seized Honda GX 390
   / Seized Honda GX 390 #11
Pull the head (I think it is just 4 bolts), and that should remove all the mystery:) Can't hurt anything.
best,
ed
Is the piston going up and down as your turn the crankshaft ?
No clue- I was just turning from nut on assembly that recoil connects to. I guess I will pull the head in next day or so. I did do a You /tube search and came across a guy that bought "Sten" brand complete head assembly with valves for $105
   / Seized Honda GX 390 #13
Don't buy anything until you pull it, please let us know what you see.
Best,
ed
Yes-latest thing I did-pulled plug and confirmed-piston is functioning as it should.
   / Seized Honda GX 390 #16
OK then, it's time to disassemble the engine and see what the problem is. As someone else said, start with taking off the head and see what you see.
for sure-next step
   / Seized Honda GX 390 #18
Well guys an update. I pulled plug and shot some WD in it and then took recoil off and put a socket on crank. Should have done that first. Turned easy as can be-for bout 270 degrees. then I pulled valve cover. One rocker moving as it should while no movement on other-other then the rocker arm was very loose-no tension either way.
So lobe came off cam? valve broke and that is why wont go past 270? And I say 270-Plus or minus like 3/4 rottion and it jams???
Rotate the engine 2 full revolutions watching the valves before you pass judgement. The camshaft turns 1 revolution for 2 of the crank.
GC- only rotates about 270 degrees! then stops
   / Seized Honda GX 390 #20
My guess would be you have a broken rod.
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
KUHN SR110 GII LOT NUMBER 39 (A53084)
KUHN SR110 GII LOT...
