Seeking advice on welding hook to FEL bucket
   / Seeking advice on welding hook to FEL bucket #101
Excellent!!! Accomplished two things at once. Hooks and extreme reinforcement to the top lip of the bucket!!! :thumbsup:
   / Seeking advice on welding hook to FEL bucket #102
Shaneard I suggest you run a bead of caulking between the welds. So water won't get under the plate.
   / Seeking advice on welding hook to FEL bucket #104
The clevis can go either way and be put in backwards to get it out of the way.
The other advantage is when it is in backwards and a chain down behind the bucket, you get maximum lift. :thumbsup:
   / Seeking advice on welding hook to FEL bucket #105
Oh here's the 5/16" hook and plate I cut off. Forgot to get picture before. This is part of why top lip was bent. IMG_3377.JPG
   / Seeking advice on welding hook to FEL bucket #106
Agreed and heat it up and dry it thoroughly before you seal it.
   / Seeking advice on welding hook to FEL bucket #107
Does anyone have pics of how to deal with the lip issue of the Kubota buckets? While I've got no problem ordering Kenny's Bolt-on hooks for the Kubota....I was just wondering if anyone's got a quick and easy way to attach grab hooks that don't rub over the lip. (And Kenny - over 50 bucks to ship to Canada? Wow!)
   / Seeking advice on welding hook to FEL bucket #108
Over $50? Who said that? The website (in the FAQ section) states $43.95usd for up to 20 pounds of product in a USPS medium flat rate box-this is what they charge, I do not profit from that. Unfortunately this is the cheapest way, I wish there was a better option for our brothers to the North.
*edit* I guess in Canadian dollars it is over $50.00
If you can weld, know someone that does, or can have it done locally then using a piece of angle iron to "box" the lip is a great solution, and it makes it very strong too.
Here is a great pic from a TBN member (and customer):
   / Seeking advice on welding hook to FEL bucket #109
Kenny...I know it's not you charging the $43.95, but the freight/post people. I was just busting your ball$ A bit. Glad to see you pay attentin to the forums. If I can't get a welding guy to do a good work-around, I'm giving you a call, alright?
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2012 WESTERN STAR 4900 SB (A52472)
2012 WESTERN STAR...
