Security & Theft Security Question
/ Security Question #21
Re: Reminds me of a skiing story
You guys are all experts next to me! /forums/images/graemlins/grin.gif
I got off the T-bar (the thing you sit your butt on as it drags you up the mountain), after falling off it many times and being pulled up with my arms wrapped around it, finally managed to get back in position... but nobody had warned me that once you ski away from this thing it's going to come swinging back and clobber you in the back of the head! Sigh. So I get off, try to look cool, and then SMACK! I'm flat on my face wondering what happened. /forums/images/graemlins/grin.gif
I won't keep taking this off-topic any further.. but there are a lot of other stories from this (my one and only) day of skiing. Like ending up wrapped around the *one* tree on the slope.. or like thinking I was doing pretty good and waving to some girls.. at which point I somehow started doing cartwheels down the rest of the slope.. or... well, you get the idea! /forums/images/graemlins/grin.gif
/ Security Question #22
I use to leave my IH2500b out at our property. I would remove the battery and, since it was a gas engine, I'd remove the rotor from under the distributor cap. That's a hard one to troubleshoot and if they did manage to figure out why it wasn't firing, how many people carry a rotor for a IH2500b /forums/images/graemlins/grin.gif
Disconnecting safety switches is a quick and sneaky way, too.
I also was fortunate enough to have a neighbor across the street that would keep an eye on it. Although one time she called the police to report that the headlights were on in the middle of the night. I couldn't figure out how, since I had removed the battery and had it at my house. I talked to the police and they confirmed that the headlights were on when they drove by. I went out there the next day and there was no battery in it and the headlights were off. /forums/images/graemlins/confused.gif
What I think happened was someone was trying to steal it, ran away when the police showed up and came back and got their battery after they couldn't start it /forums/images/graemlins/tongue.gif
/ Security Question #23
There are no small hills at Taos! Especially the one you see when you drive up! Yikes! Great skiing though. I think they have a tractor or two (feble attempt to stay on topic). They probably have an alarm (second feble attempt to stay on topic). /forums/images/graemlins/smile.gif
/ Security Question #24
make sure it is insured, park it out of sight,take all precautions that are resonable, and u should be fine. remember tho, that if THEY REALLY WANT IT, nothing short of sitting on it with a 12 ga. will deter them.
/ Security Question #25
I just act like a lunatic while I am out working with the tractor, I am pretty sure it's working I get funny looks from passing cars on the road in front of my house all the time!
Gun on side lots of cursing and talking to myself...I must be a good actor or???......nah, I'm OK.
I still think they'll go after someone elses tractor /forums/images/graemlins/crazy.gif Hope this works as well when it's my daughters time to start dating!
/ Security Question #26
The trick I use on a gas engine is to swap the coil wire with one of the plug wires on the distributor cap. When they try to start it it fires once every other revolution when the rotor lines up the cylinder the coil wire is on and the center tower. It won't start but it'll give a good healthy chug.They'll grind the battery down thinking it's just one or two more turns before it starts. /forums/images/graemlins/grin.gif
/ Security Question #27
Like the other guys said.. it was talked about before, and short of an armed guard.. tere is nothing you can do to 'lock it in place' that you could remove/undo in reasonable time that someone else can't undo one night.
Chainns are no good.. bolt cutters get them.. if not bolt cutters.. torches pretty much cut everything.
Tractor electronics are pretty basic... not much you can do that a set of jumper wires won't undo.
Something like removing a rear wheel would slow em down.. and you too.
Park it at a trusted neighbors house.. have good ins.. or park it in some other structure.
One thing we do with heavy equipment at const sites, is park the most theft prone stuff up against a tree or something, and then use another piece of equipment to place some large object.. say.. a stack of pipes.. or pallet of blocks in front of it.. in effect pinning it in.. etc...
Still no guarantees. Since I've worked there the last 12 years, we've had a dozer and dump truck stolen from jobsites.. etc... theves can get it if they have time...
Soundguy
/ Security Question #28
See guys, I weren\'t so stupid after all!
You use a big honkin' crane or some TEREX earthmover to put two immovable objects on either end of your CUT!
I was on the right path, just didn't elaborate enough!
Have a great weekend.
Ron
/ Security Question #29
Re: See guys, I weren\'t so stupid after all!
</font><font color="blue" class="small">( ( You use a big honkin' crane or some TEREX earthmover to put two immovable objects on either end of your CUT! ) )</font>
If you use the TEREX machine to put immovable objects in front of and behind your tractor, what do you put around your TEREX to keep it from being stolen?
As a side note, I used to work in the TEREX plant, after it closed when it was being leased as warehouse space. My goodness, that's a big building! There are some spots where there are literally tire tracks in the concrete from all the weight being driven over it for years!
/ Security Question #30
<font color="blue"> They'll grind the battery down thinking it's just one or two more turns before it starts. </font>
Pure genius /forums/images/graemlins/grin.gif
2019 Freightliner B2 School Bus (A59230)
2019 Freightliner...
1965 Fontaine PS2824SP 28FT 15 Ton S/A Flatbed Trailer (A59230)
1965 Fontaine...
2004 Toyota Camry Solara Coupe (A59231)
2004 Toyota Camry...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
John Deere Z994R (A60462)
John Deere Z994R...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
