Secondary Hydraulics question
   / Secondary Hydraulics question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Does anyone know the hydraulic properties on an 1850 of the Grapple, Thumb, Locking mechanism hydraulics? GPM and PSI? Maybe how it all sort of works compared to the PTO?
   / Secondary Hydraulics question #2
I have read this thread 3 times and I still cannot understand what your question is!!. The main PTO. and Aux. hookups( non-PTO ) are totally different beasts (flow & pressure are different on both circuits ). Could you make your question a little clearer?:confused:
   / Secondary Hydraulics question #3
I agree, try asking your question a different way, what you have typed makes no sense:confused:
   / Secondary Hydraulics question #4
I think he's looking for the specs on the Aux PTO and the main PTO, to compare them. I can find the info on the main PTO, but not the Aux PTO.
The main PTO is 18 GPM @ 3,200 PSI
What are the specs on the Aux PTO?
Yes, indeed, you are correct. I am back on my crack cocaine addiction so typing something coherent is becoming much harder to do.
I was just wondering what the Specs are on the AUX PTO circuit. The circuit I am referring to is also the circuit you use to operate the backhoe, grapple or locks for the quick attach...
Sorry for the confusion... We had a llong day of casting major acrtresses and always leaves me star struck and in a daze...
Carl
   / Secondary Hydraulics question #6
Us PT guys knew what you meant.
   / Secondary Hydraulics question #7
There are three hydraulic pumps on our PT425.
1. Main PTO is rated at 8GPM @ 2500PSI.
2. The auxillary PTO which runs the steering, lift and quick attach circuits is rated less GPM but still 2500PSI. I can't recall exactly, but I think it is 6GPM.
3. The variable volume pump that drives the main drive wheels I have never gotten specs for.
My suggestion would be for you to call Power Trac at 1-800-THE-YARD and just plain tell them you are interested in their product and would like some information regarding the GPM of the pumps so you can decide if it will push the implements that you want to use.;)
Interested? Heck, I bought one. But the truck caught on fire and now it won't show up until Wednesday or Thursday.
Living Vicariously through all of you. My little PT fix. Taking a week off from LA, going to fly up and play around with it and look at all the tulips and apple trees in bloom, then back to reality...
Thanks for the info on the PT. Will call Tazwell on Monday...
   / Secondary Hydraulics question #10
Then why didn't anyboby respond to the question?
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
SCHAFFER 2430SLT LOT IDENTIFIER 137 (A53084)
SCHAFFER 2430SLT...
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
1273 (A50490)
1273 (A50490)
16ft Heavy Duty Aluminum Ramps (A53472)
16ft Heavy Duty...
