Seat replacement on 1500 series
   / Seat replacement on 1500 series #1
timpar
MF 1540
Any of you guys look into replacing the stock seat on a 1400/1500 series? I really like the "wrap around" seat on my 135 but it does not look like the bottom plate will match. I mow a bumpy field that just wears my butt out. Any suggestions?
Thanks.
   / Seat replacement on 1500 series #3
Does your seat have a cloth pattern or is it a slick material?
It is the grey vinyl seat. Adjustable front to back, and has weight adjustment. Just not to shock absorbing.
   / Seat replacement on 1500 series #5
Look into the seat that has a cloth like pattern on seating area and back. It is day and night different in comfort. Or you could get a new one with wrap around arms rests at TSC for a lot less.
   / Seat replacement on 1500 series #6
Northern tool has a good selection here is a sample. http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=27777&R=27777
See Larger Image
Wise Universal Tractor Seat with Armrests
Ride in comfort with foam-cushioned armrests! 2 foam-filled seat cushions are attached with Velcro® so they remove easily when it rains. Black vinyl covering. 16-gauge metal frame. 4in. to 11 1/4in.W x 11 1/2in.D mounting hole patterns fit most tractors. Not for center mount. Seat dimensions: 18 3/4in.W x 16 1/2in.D x 17 1/2in.H. Overall width (including armrests): 21 3/4in. U.S.A. See below for additional product information.
In Stock
Ship Wt. 29.0 lbs... Calculate Shipping
Item# 11754
Discount Price $84.99
110% Guaranteed Lowest Price!
Qty
Features + Specifications
Wise
Jerry, is that a MF seat option? If so how can I find out about it and other "options" for the MF tractors other than dealer? The MF website has nothing I could find.
Comfortable looking seat. But did you see the $399.00 seat?!! That's one for the XMAS list, LOL!
   / Seat replacement on 1500 series #9
timpar,
I didn't look to see if you had a 1400 or a 1500 series until now. The seat that I was referring to was on the 1433 and 1440 (non-V) tractors. I don't know if the 1400 and the 1500 use the same seat or not. The 1433 and 1440"V" tractors had a slick smooth seat like on the 1200 series. I have forgotten which seat is on the 1500. The cloth looking seat is a real change from the smooth seat. It is a lot thicker and rides a lot better. To help tell if it fits, it mounts with a long pin in the front of the seat. The pin is also what it hinges on to tilt forward.
Yes, it is a long pin. Is this a Massey item or do you have an alternate source?
Thanks.
6' King Kutter 3 pt Disk (A50515)
6' King Kutter 3...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
3 pt Post Hole Digger (A50515)
3 pt Post Hole...
Loader Arm (A51691)
Loader Arm (A51691)
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
