Seat replacement on 1500 series
   / Seat replacement on 1500 series #1
timpar
MF 1540
Any of you guys look into replacing the stock seat on a 1400/1500 series? I really like the "wrap around" seat on my 135 but it does not look like the bottom plate will match. I mow a bumpy field that just wears my butt out. Any suggestions?
Thanks.
   / Seat replacement on 1500 series #3
Does your seat have a cloth pattern or is it a slick material?
It is the grey vinyl seat. Adjustable front to back, and has weight adjustment. Just not to shock absorbing.
   / Seat replacement on 1500 series #5
Look into the seat that has a cloth like pattern on seating area and back. It is day and night different in comfort. Or you could get a new one with wrap around arms rests at TSC for a lot less.
   / Seat replacement on 1500 series #6
Northern tool has a good selection here is a sample. http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=27777&R=27777
See Larger Image
Wise Universal Tractor Seat with Armrests
Ride in comfort with foam-cushioned armrests! 2 foam-filled seat cushions are attached with Velcro® so they remove easily when it rains. Black vinyl covering. 16-gauge metal frame. 4in. to 11 1/4in.W x 11 1/2in.D mounting hole patterns fit most tractors. Not for center mount. Seat dimensions: 18 3/4in.W x 16 1/2in.D x 17 1/2in.H. Overall width (including armrests): 21 3/4in. U.S.A. See below for additional product information.
In Stock
Ship Wt. 29.0 lbs... Calculate Shipping
Item# 11754
Discount Price $84.99
110% Guaranteed Lowest Price!
Qty
Features + Specifications
Wise
Jerry, is that a MF seat option? If so how can I find out about it and other "options" for the MF tractors other than dealer? The MF website has nothing I could find.
Comfortable looking seat. But did you see the $399.00 seat?!! That's one for the XMAS list, LOL!
   / Seat replacement on 1500 series #9
timpar,
I didn't look to see if you had a 1400 or a 1500 series until now. The seat that I was referring to was on the 1433 and 1440 (non-V) tractors. I don't know if the 1400 and the 1500 use the same seat or not. The 1433 and 1440"V" tractors had a slick smooth seat like on the 1200 series. I have forgotten which seat is on the 1500. The cloth looking seat is a real change from the smooth seat. It is a lot thicker and rides a lot better. To help tell if it fits, it mounts with a long pin in the front of the seat. The pin is also what it hinges on to tilt forward.
Yes, it is a long pin. Is this a Massey item or do you have an alternate source?
Thanks.
2018 Ford F-150 XL (A50120)
2018 Ford F-150 XL...
Onsite begins 8:30am / Online begins 9:30am (A50121)
Onsite begins...
Electric Mobility Scooter (A51694)
Electric Mobility...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
