Seat info needed please
   / Seat info needed please #1
tsmithco
Bronze Member
SW Ohio
2015 Kubota L5740
I bought a ym2002 a couple months ago. It doesn't have the original seat - someone put 2 steel supports on the stock mounting location and drilled custom holes in those to attach a universal seat to the tractor - HARD MOUNT. Even with turf tires and lower pressure, when I mow over the bumpy area of yard, it kills my spine. I tried a universal seat with suspension from tractor supply, but it sits way too high. So.... The stock seats - are they like a lawnmower? a pin in the front, and some sort of springs underneath in the rear? best pic I could find was from Hoye's site (http://www.hoyetractor.com/storeimages/seatontractor.jpg).
Save my back! Thanks!
   / Seat info needed please #2
That looks like a replacement seat that Hoye sells. I have the same seat for my YM1700. Mine came with an original seat. It was an old fashion pan type seat. It was not comfortable at all and small too. I kept the rubber bumpers from the pan seat and attached them to the seat support. It helps somewhat reduce the shock. I have seen some use lawn more seat springs and even old valve springs on the seat as well.
   / Seat info needed please #3
here is a pix of what i did, also the seat was moved back 3½" to accommodate my long legs. i do not think anyone sells a bolt on kit for springy seats, so home brew design and fabrication will be up to you.
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
296385 (A57192)
296385 (A57192)
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
