sears super 12
/ sears super 12 #1
collector121
anyone know anything about sears garden tractors?? I have a sears super 12 i think the head gasket is blown in. anyone know where to find parts??
/ sears super 12 #2
You may have to provide more information. At least I'm not familiar with the super 12. Did you buy it new? How old is it? Which engine does it have? Do you have the manual? If not, can't you get one from Sears? One thing I've always liked about Sears is their exploded views and parts lists in the manuals. And of course, Sears is where I'd probably go for parts.
/ sears super 12
so the head gasket is definitely blown, amazing thing is it still runs. i started it up today and i can feel air coming out from between the head and block. numbers are as follows:
Tractor:
Model: 917.25311
Serial: 1377
Engine:
Model: 143-602022
Serial: 1029E
/ sears super 12 #4
Let's see if this link works right. Sears shows to have that head gasket in stock for $5.32. Original part #32246A, substitute #32246B.
In the event that you need other parts, go to Sears.com and toward the upper right corner, click on PartsDirect, then enter the model number (in the current case, the engine model number instead of the mower number). Of course it shows some parts in stock, some replaced with new numbers, and some no longer available.
/ sears super 12
awesome, thanks. i just ordered a new gasket. hopefully it fits and will work!!
/ sears super 12
ok, i finally got the thing apart, and the head, piston, and valves look ok. no cracks or scratches. is there any specific order in which to install a new head gasket? or do i just slap the new one on there and bolt the head back on? how can i clean these things up without damaging?
/ sears super 12 #7
Do you have a die grinder? They make some pads that look like non-metallic scouring pads to use on a die grinder. They work great for removing old gasket material, carbon, and even to de-glaze brake rotors.
/ sears super 12 #8
Use a torque wrench to make sure you don't over tighten the gasket and crush it so bad you end up causing it to fail again. Also as Bird said make sure you scrape off all mating surfaces.
When you tighten the bolts do it in a cross pattern like you would then replacing a wheel.
/ sears super 12 #9
no i did not buy it new. i do not have the manual. it is very old. sears did not have the gasket. how ever i did get it ordered through the local co-op. it will take abot 10 days. Do you by chance know what the head bolts torque on?
2021 JCB 35Z-1 Mini Excavator (A64553)
2021 JCB 35Z-1...
2015 Ford F-550 Crew Cab and Chassis Truck (A64556)
2015 Ford F-550...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
(3) JOHN DEERE DRY FERTILIZER DISTRIBUTORS (A64278)
(3) JOHN DEERE DRY...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2022 EZ-GO ELITE...
