Seafoam
   / Seafoam #81
I have used seafoam for years in small engines especially marine, dirt bikes and outdoor power equipment. Mainly as a preventitive I will put a few ounces in the mix. I have had almost no carb issues for many years. I have bought it at O'Reilly's by the gallon for $50+. I did see Coleman Fuel at Walmart for $9.99 per gallon and the label said that it has rust inhibitors in the fuel. My question is would using the coleman fuel be almost the same as seafoam? In my earlier truck driving days we used lots of rubbing alcohol in the gas tank to fight condensation or bad gas. It made sense at the time.
The new fuel doen't need anything added. Until the mid 80's if you let an open top pail of gasoline evaporate away. There was a nasty layer of gum and varnish left behind. Last time I looked it was 2012 and gasoline is clean and stays clean . Otherwise emissions vehicles would fail. Coleman lantern fuel/naphtha gasoline is just very low octane straight cut gasoline off the distillation tower. It's just a bulk filler to dillute the IPA and mineral oil with.
   / Seafoam #82
The new fuel doen't need anything added. Until the mid 80's if you let an open top pail of gasoline evaporate away. There was a nasty layer of gum and varnish left behind. Last time I looked it was 2012 and gasoline is clean and stays clean ..
except it now absorbs water copiously.. :(
   / Seafoam #83
Ya, and eats up the plastic in your small engines fuel system.......what a great improvement!
   / Seafoam #84
yep.. kinda like having the mother in law staying with you. not only is it inconvienient and expensive.. it's inconvienient too.. ;)
   / Seafoam #85
10% ethanol will not attack quality fuel system plastic or rubber. Dumping in methanol which is sold as the lower priced gasline antifreeze will certainly ruin any non E85 plastic or rubber.Not a problem here as Only 100LL is allowed in any smal seasonal engine here.
   / Seafoam #86
Curious, About coleman fuel...have you burned it for motor fuel? How good a cleaner does it make. I have several gallons in my shop from camping days...I know we burned White Amoco gas in our coleman lanterns and stoves..So. Who can tell??
   / Seafoam #89
10% ethanol may not attack plastic and rubber in NEW cars and engines, but it is a different story with older engines. And it does absorb moisture.
   / Seafoam #90
For cleaning, Amsoil power foam is 10000X better then seafoam and cheaper. Also B12 Chemtool is way better. Why anyone still buys overpriced seafoam is beyond me.
Because we can buy Seafoam almost anywhere.
2000 Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2000 Lull...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
KUBOTA L2650 TRACTOR (A51243)
KUBOTA L2650...
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2017 VOLVO ECR88D EXCAVATOR (A51242)
2017 VOLVO ECR88D...
