mohamer
WOW! that was a major dose of SeaFoam but it sounds like it perhaps freed up sticking rings. Saturn had this issue and some of the 2011+ Subaru's are reporting oil burning issues. I suspect ring-grove build up may be the common thread in these cases.
It is good to know the time line that it took the SeaFoam to do its thing in your case. I have used it in the fuel, engine and ATF successful.
Thanks for reporting your SeaFoam experience. It will not fix cracked heads and holes in pistons but I have seen in resolve/prevent crud related machine issues.
I did the first oil change in this new to us 2010 Subaru Forester that came with 105K miles but with new head gaskets, plugs, water pump and timing belt 2K miles earlier just because the oil was getting darker due to our Archoil AR9100 usage. I do think dumping in a can of SeaFoam right before an oil change gives a better drain out of build up about 100% of the time.
Gal,
I measured what the can said to put in, I think it was 20 oz. Did not use near a full can
Lem,
I use Stabil too, it sits right beside the can of Seafoam I always have in the shop..
They are used for differing applications as far as I am concerned, Seafoam for cleaning fuel systems and other things, Stabil to stabilize Fuels.
I put Stabil in all my Gasoline cans when I buy gas, I also put it in my Motorhome when I am not on the road with it, it holds about 80 gallons, I don't want it to go bad..
John kb0ou
