Seafoam
   / Seafoam #181
   / Seafoam #182
Anyone use this?
Absolutely, it has been a great product for my machines. It has really helped my gasoline lawn tractors to start consistently through the cold months. It stabilizes, preserves your gas or diesel. Use it for the Mahindra as well. I use about 1/3 or 1/4 a can per 5 gallon container. I try to always have it on hand. It may add a bit of smoke to your exhaust.
   / Seafoam #183
i see the point about an easy grab for a back field working on a tractor, needing a charger for a drill or lights or just battery charger etc.
   / Seafoam #184
Skip the seafoam. Use water of Amsoil Power Foam 10X better.
   / Seafoam #185
Dump a dose of Isopropyl alcohol gas line antifreeze for fuel injected equipment in the tank instead. It's the active Ingredient that dissolves gum, goo and varnish while absorbing water.
Draining the water/condensation from the carb bowl would start a lot of engines that magic elixers have "saved".
* * *Draining the water/condensation from the carb bowl would start a lot of engines that magic elixers have "saved".
Do I hear an echo in here?
   / Seafoam #186
Sea Foam is just a 70 year old product to remove piston carbon build up vs removing the head and scraping it clean in outboard engines. It just so happens to work quite well in crankcases, automatic transmissions and fuel system too from our usage experience.
   / Seafoam #187
+1 I have used it for over 20 years in my auto repair business with success. Following the instructions I use it 1/3 tank. 1/3 crankcase, 1/3 thru the intake and let it sit 30 minutes and drive it works like a charm every time even kills a few skitos on the test drive too just another benefit. :laughing:
   / Seafoam #188
i've fogged a few with atf before.. :)
   / Seafoam #189
Yesiree that will do it! :thumbsup: I had the neighbors call the fire dept on me one time when I had smoke pouring out of all doors dont remember what I ran thru that car but it was a hoot. Too bad the county was sent on a false alarm oh well stuff happens. :)
   / Seafoam #190
If most people caught somebody pouring baby oil, Coleman lantern fuel and gasoline antifreeze into an automatic transmission. There would be shouting, threats and either a beating or the cops being called.
1987 Ford 2110 Tractor (A50514)
1987 Ford 2110...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
2020 EZ-GO Elite RXV Electric Golf Cart (A50324)
2020 EZ-GO Elite...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
