SCV stops retracting cylinder when lever is pushed all the way
   / SCV stops retracting cylinder when lever is pushed all the way #11
Sorry for misleading if the OP is not using the joystick, but sticking to my guns if so. On my JD and all other 5xxx utilities I've seen having only std SCVs they are controlled by the joysick. IIRC, additional/optional SCVs (3) have their own separate operating levers as factory-installed. Didn't see where the OP specified how many SCVs are on his, or see which controll lever(s) he's using in the video. Of course I'm assuming his 5055E is minimally equipped, as so many like it are.
It's not only joystick valves that have float or regen functions, and I'm not looking at the whole installation. :ashamed:
This is my setup for the Allied loader (495) I added, using std SCVs & joystick:
Just when I thought JD offered similar things on ~similar models ... :(
   / SCV stops retracting cylinder when lever is pushed all the way #12
See posts 2 and 3.
Any SCV other than the loader dump/curl valve will not have REGEN.
The REAR SCV (and there is only one on this tractor) controls the sprayer volute. I can't use the joystick because it controls the mid mount SCV's which operate the loader.
   / SCV stops retracting cylinder when lever is pushed all the way #14
I would say that there is a 90% chance that you have a bad quick connect. Can you temporarily plug into the loader valve just to isolate the problem?
   / SCV stops retracting cylinder when lever is pushed all the way #15
(#3) It is the rear SVC. Only one on the back of this tractor.
Read that wrong, huh? :(
Totally missed the cab thing, too. :duh: (Might have noticed that in a pic. :ashamed:) Envy the cab's mid SCUs for the joystick, but found the kit wa$ a bit much. (Creaky old guy plumbed 90s onto his QDs for grip.)
Hope the QD is all you have to deal with. :thumbsup:
I suppose I am also leaning to it being a quick-disconnect issue. Went out earlier and tried it and it is working normally again. :confused:
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
Metal Sunflower Lawn Art (A55853)
Metal Sunflower...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
2022 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A52707)
2022 CATERPILLAR...
