screw up
/ screw up #1
bsf619
wooster,ohio
johndeere 3320
so I screwed up and hooked the battery up backwards on our john deere 5310 I'm looking for some ideas on just what I smoked any help would be appreciated
/ screw up #2
I assume you then hooked it up correctly and are having issues? What does it do (or not do)?
/ screw up #4
No dash lights or anything? Turn signals?
Sorry to hear it. You are not alone in making that mistake though. Hopefully one of the Deere guys can help out.
Sounds like the ignition switch itself got toasted though if absolutely nothing works. I would expect the signals or dash to work if it was any thing else.
/ screw up #5
How long was it connected wrong? If just a short time, that is one thing....if a long time the battery itself could also be damaged
/ screw up
just long enough to get smoke rolling from under the hood I back by the dash
/ screw up #8
Assuming the fusible link being replaced allows the tractor to start, the next thing I would check is the alternators charging output.
Reverse polarity hook up can in some cases damage the main rectifier diodes and possibly the regulator to.
/ screw up #9
^^true....then you have those computer boards that seem to be in most modern equipment too. In the OP's case, I'll hope the fusible link is all of it.
/ screw up #10
bsf619...keep us posted on your findings please!
17601CFL (A59228)
17601CFL (A59228)
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
