Screw Type Log Splitter
   / Screw Type Log Splitter #41
I have a Stickler that I bought at least 25 yrs. ago. I've split many cords of wood with it,without incident. Like working with any power tool one must be vigilant! I run my tractor at idle speed with the PTO on,I figure the screw speed to be 150 RPM. The single most important rule is,don't split anything shorter than 3'. I generally split my wood at 4' lengths.
   / Screw Type Log Splitter #42
I can't speak much about Stickler log splitters but don't immediately dismiss all screw type log splitters as dangerous or unsafe. I've got a Hydrocut screw type log splitter which is 3 point linkage mounted and runs off the PTO. It's very different compared to the Stickler though. I've never had any safety concerns with my Hydrocut. I even let my teenage kids use it with supervision and as long as you use it correctly it's very safe. My Hydrocut splitter is an HC2X model and it can split some big old logs let me tell you. It doesn't look very impressive as the cone must be roughly only 10 inches long and 5 inches wide at it's widest part. When you see it working it's pretty unbelievable what it's capable of. I've split all different types of wood with it including some really knotty stuff and it breezes through it no problem. You can split small stuff on it as well which I couldn't do with my ram splitter. I'd never go back to using my ram splitter now. The ram splitter was so crap in comparison and it was more expensive to buy too. I honestly can't recommend this screw type splitter enough. Definitely one of the best things I've invested in.
   / Screw Type Log Splitter #43
Just a quick follow up to my last post. I've just watched the video footage of one of those Stickler splitters in action. OH MY GOD! That thing looks lethal. I can't believe those things meet health and safety requirements?! What if you get some clothing wrapped round it or a log somehow twists your arm round it? How do you stop it? Is there an emergency cut off switch somewhere cause I can't see one? My screw log spltter is part of a welded machine with a platform bed underneath the splitting cone. It has a shear pin to prevent tortional overload and a guard rail to grab incase you trip. Most importantly it has a safety cord you pull as an engine cut off switch incase you get into difficulties. The platform on my splitter is there to place the log onto and because the log is touching the platform underneath it prevents the log being spun around by the cone. What stops a log windmilling round on this stickler thing? Is it only for big heavy logs? Seems like a pretty dangerous bit of kit to me. Very different to my Hydrocut splitter. Know I understand why people were saying screw splitters are dangerous. I'd never let my kids use that Stickler thing. I don't think I'd fancy giving it a go myself! I'm sticking with my Hydrocut screw splitter!
   / Screw Type Log Splitter #45
Those screw type splitters have been around since at least the early 50's. The one I saw working was bolted to the rear wheel of a truck. The rear wheels were jacked up, and the other wheel was locked down. They pushed the log sideways into the splitter with a 2X4 and it did it's job. The only reason to get close was to pick up the split pieces.
   / Screw Type Log Splitter #46
That hydrocut does look pretty sweet. If I could find one, and it was significantly cheaper, I'd give it a go.
Looking like I'm going to have to spend a bit more than a grand on a hyrdraulic tow behind.
   / Screw Type Log Splitter #47
Don't remember where I found this, but here's another pic.
   / Screw Type Log Splitter #49
To the math experts out there, how would you ever figure the power/force for one of those splitters?
   / Screw Type Log Splitter #50
I bought a Stickler about 25 years ago and used it for several years on my pick up. I looked at the instruction book before posting and it said to keep the point 10" above the ground. It also had a safety/kill string that went to a switch you had to wire to the engine coil.
As far as operating it was ok for a guy in his early 20s. It worked best with three people. One handing logs, the operator on his knees and another guy taking split wood away. I only remember having a log start flipping around once when I let someone else run it. It didn't work on crotches or knotty wood very well. You had to choose what you split and some times an ax was quicker. Some times if the log didn't split before you ran out of screw the log would be stuck with the screw spinning inside the split.
I haven't used it in 20 years and have had different hydraulic splitters sense. My favorite is a 3 point hooked to the power beyond on my JD 3320. It is just as fast as my 6 horse hydraulic with a two stage pump but stronger. I looked at mounting the stickler on my tractor but the cone is threaded the wrong direction to feed the log on.
I have never ran a PTO screw splitter but my stickler worked the same way. Not sure how you would shut it down in an emergency or split shorter stuff with the brace arm so far away from the screw. Like everyone else has said It's a machine and has no care for human life.
Dan
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Misc Tires (A56860)
Misc Tires (A56860)
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2015 Freightliner Coronado (A60460)
2015 Freightliner...
TANK MANIFOLD (A58214)
