Grading scraper blade ?
   / scraper blade ? #21
Not sure. I have never moved them in 700+ hours. It works fine with my BH, Bush Hog, Finish mower, Blade, and Post Hole Digger.
Here is the only pic I can find with the blade on it. I will take one tomorrow.
Chris
Chris, from your picture, it looks as though your tractor carries your rear blade very good, but are you sure that the cutting edge is 30" off the ground? It looks more like 12"-16" at most. :confused:
   / scraper blade ? #22
I would think that a 6' wide scraper blade is too narrow for a 50HP tractor.
We have a pretty heavy duty 7' Tufline rear blade on a Kubota L4310. Heavier is better with rear blades - my dealer told me of having to replace lighter duty blades due to crimping.
As other have posted, check your lift capacity and/or ask you dealer for a trial fit.
I think that the OP said that it was a 6' blade rated for a 50hp tractor. His tractor is 30hp and wanted to know if it would be ok on his tractor.
2009 Kubota M108S (A53317)
2009 Kubota M108S...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Portable Restroom (A54865)
Portable Restroom...
Swict 7' Fork Extensions (A56469)
Swict 7' Fork...
2020 Deere 50G (A53317)
2020 Deere 50G...
