Scotts John Deere riding mower engine is missing
   / Scotts John Deere riding mower engine is missing #1
dssheard
Power King
Recently, I had a problem (with a Scotts John Deere 2046) which I was gratefully pleased several on the discussion board properly diagnosed--a bad solenoid. When I put the tractor back together, there is backfiring. I did not really do much except some electrical work--fixed a ground wire, changed the solenoid. However, in the process, I sanded and oiled the flywheel. I moved it manually to sand it so when it passed over the magnetos ( I think that is what they are), the spark would be good. However, now the engine won't start. I am wondering what I could have done. Any help out there? I have spark, just bad timing it seems. Do I need to pull the flywheel and check something underneath? Could I have switched some wires?
Lost in Maryland.
   / Scotts John Deere riding mower engine is missing #2
There is a key to align the flywheel and crankshaft. Remove flywheel and make sure the key is not bent or sheared.
   / Scotts John Deere riding mower engine is missing #3
when i read your title...i thought someone stole your engine lol:laughing:
Thanks for the advice. I'll try to pull the flywheel and check it.
Dan
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
HOMEADE 8' X 22' TRI-AXLE TRAILER (A60430)
HOMEADE 8' X 22'...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
