Scotts 2554 charging problem
/ Scotts 2554 charging problem #1
Welder455
Lathrop,Missouri
Scotts 2554
The charge light comes on after I start it and engage the electric clutch to mow. I need tips on what to check out. Like how to check a rectifier/voltage regulator. How do I check voltage from the flywheel. I could do the work on everything else I'm more skilled in mechanics than electrics.
I did replace the old battery after it drained, thought it might be bad .
I'm a new member of the forum, but have checked it out a few times. Good info from everybody.
/ Scotts 2554 charging problem #2
With your meter on AC carefully probe the 2 outside wires at the regulator. You should have ~ 30 VAC . If you don't, you have no stator output, but before ordering a stator- pull the flywheel and determine if the magnets on the flywheel are still attached or not. If you do have stator output, next verify that you have a clear 12 VDC path to the center wire. If yes and yes, your regulator is likely defective. But before replacing 1) verify that the regulator has a clean ground strap from the mount screw to the block and 2) Pull the terminal connector and run the test again which sometimes allows the regulator to reset.
/ Scotts 2554 charging problem #5
On many lawn tractor models the wiring is a bit different than you would expect.
Yours is likely the same.
For the pto electric clutch, +12 volts is supplied to it all the time the key is ON.
When you use the switch to engage the clutch, you are providing a path to ground so that safety switches etc can easily be in the ground circuit. Also, the relay that shuts down the mower deck when you back up, cuts the ground thus disengaging the electric pto clutch.
The dash display is just a simple low voltage electronic sensor and is stupid.
It has a need for a ground and a power wire. If the overall ground for the many things on the tractor is using a corroded connection to the frame, and the low voltage indicator is likely using the same ground, then when you engage the pto clutch, the grounding of the clutch may be enough to just engage but it is also providing some voltage to the ground for the dash indicator causing it to illuminate.
Check for a green wire attached to the tractor fame or a green wire connected to the negative battery terminal. It will be a light gauge wire.
This cub cadet wiring diagram is not an exact image of what will be where on the tractor. Its purpose is to show the function of various circuits so it does not show the voltage sensor ground and the pto clutch ground being tied together and connect to the frame or negative battery terminal.
If you have a cheap, less than $10 multimeter to measure the battery voltage, you will find it around 14 volts when the engine is running and the pto engaged but the dash light will be on which is why I say it is a stupid device.
Dave M7040
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2026 Electric Tricycle (A64194)
2026 Electric...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
