Scored a welder. Is it any good?
   / Scored a welder. Is it any good? #51
LD1, take that java calculator you used. Put in a 1A load on a 50' extension cord. What do you get?
I don't trust the results. They are very overly conservative. I think in your specific examples, they are under conservative.
I use a 30' SOOW 10/3 extension on my welder. It uses 28A at 230V rated output. I have no worries.
My vacuum has a 30' 17AWG for 12.5A. It gets warm with use. I don't like that. It should have a 14AWG cord, but it is intermittent use. It's UL listed, go figure.
The Mrs. likes to use those 1500W heaters in the winter. I ***** about it because... they draw over 12 amps and some have 16AWG cords. They get warm and the circuirt breakers are probably 15A on the outlets she uses. Technically it gets the job done, but I don't like it. I guess we're OK because the insulation is rated for 105ーC.
Go to TSC 12/3 Extension Cord and tell me what you would do if you had a 15A load 100' away? Plug the 1500W heater in an see how the package performs. Better yet, plug in a 1 1/2 HP saw in and see how it likes it!
In the end, you can use whatever cords you want, and you may be reducing the margin of safe operation. I think a 12AWG cord is decreasing the safety margin. Check out the following: Portable power cord cable SO 10 5 SOOW 12 4 16 3 10 2 . They have a decent lineup and "suggested" amp capacities.
   / Scored a welder. Is it any good? #52
LD1.
Think of electricity as water.
Think of voltage as pressure.
Think of current as volume or flow rate (gpm).
A 600V cable vs a 48V cable is like a 1/2" hydraulic hose versus a 1/2" garden hose. One can withstand more pressure (voltage) than the other before it leaks (read shocks you) but both can carry the same flow rate (gpm or amps) as the other.
A #4 cable versus a #14 cable is like a 2" hose versus a 1/2" hose. One provides a lot less resistance than the other. At low flow rates (low current) they both work just as well, but as the flow rate increases, there is more resistance to flow in the small hose than the large one - therefore some of the pressure (voltage) is lost travelling through the hose - that loss being in the form of heat, which further increases the resistance increasing the loss even more. That drop in voltage at the outlet also means more current has to flow to your tool / welder to accomplish the same work. It spirals.
I'm sure you can understand how more length also increases the amount of pressure lost (=heat generated = voltage drop) during transmission, hence why #14 may be okay up to xx', but #12 is required for longer runs.
Electrical code takes into account these factors, plus cooling factors (free air versus shielded), differences between AC and DC applications (we will skip eddy currents and so forth for now), solid versus stranded, as well as a number of other things, adds an appropriate safety factor to it, and determines a safe size of wire for each application. NEC also has a special section for welders where it takes into account the sporadic nature of the process and allows a smaller wire to be used - although a wise electrician will use the larger wire size any way.
Interestingly not all electrical authorities use the same rules. Here in Canada - #14 wiring is fused at 15amps for household use, I believe in the US it's 20amps.
Point of the matter is - use the right wire for the application, if in doubt - consult an electrician or someone familiar with the code. No one on here is going to use a garden hose as a poor mans substitute for a hydraulic hose (I hope!!) so why would one use the wrong wire to hook up their welder?
   / Scored a welder. Is it any good? #53
US = 15A breaker for 14ga wire, 20A breaker for 12ga wire.
   / Scored a welder. Is it any good? #54
LD1.
I was wondering when someone was going to use the good ole water analogy:D
Quite simply the flow rate isn't going to be the same. a 1/2" ID garden hose @50psi is going flow a lot less than 1/2" ID Hyd Hose @ 3000psi
For this reason is why I have never liked the water analogy. Everyone compairs amps to flow, but with water, increase the pressure, you increase the flow. with electric, if you increase the volts, the watts go up, ant not the amps.
   / Scored a welder. Is it any good? #55
I did that and it said 14ga. I also lowered it to .001amp and 1ft and it still said 14ga. So I have come to the conclusion that that particular calculator doesn't go smaller than 14ga
Other factors:
4. conductor material (Cu, Al, being the most common)
5. single wire in air (your alternator wire) or bundled (AC in a conduit)
6. Regulatory Agency (Mil-W-5088, NEC, UL/CSA, TUV, CE, AIA, FMVSS, etc)
There are others but this is what comes to mind at the moment.
I did mention those things except the regulatory agency.
For the sake of argument, pretend their is no regulatory agency. Because what I am trying to do is understand the science and math behind the reccomendations they make, and not just because "We are the big bad NEC, or whatever, and because We said so"
   / Scored a welder. Is it any good? #56
The two act exactly the same. If you increase the voltage, the current and power go up. The flow will find it's balance with the given source of effort (pressure or voltage) and the resistance seen.
   / Scored a welder. Is it any good? #57
I sure as **** wouldn't run anything smaller than 8 ga. for more than two feet......
   / Scored a welder. Is it any good? #58
You're confusing a few things here... There is a difference between the current carrying capacity of a wire and the power used by a tool. "Watts" as a measure is typically used to determine how much "power" is required to do a certain task such as spin a wheel, light a filament, heat coffee, etc.
In other words, "Watts" is typically used in reference to loads or generating capacity. Let's say you have an electric motor that has wiring terminals for either 220V or 110V and a power rating of 1hp. (1hp = ~746W) If you have the motor wired up for 110V it's going to be pulling about 6.8 amps. But if you switch it over to the 220V wiring, it's only going to be pulling 3.4 amps. Either way it's still a 1hp motor and it's still using 746 watts. Granted, these are ideal numbers that would be larger in the real world due to inductive losses, etc but it gives a good example of why Watts don't necessarily increase with voltage. If you hooked those 110V windings up to the 220V supply the motor would still draw close to the 6.8 amps that it did on 110V but it would also be spinning twice as fast or producing twice as much torque, at least until the windings overheated and the whole thing melted.
As for breakers, that's simply a matter of how the ratings are calculated. In a normal single-phase 220V system in the US, you have 3 wires. 2 Hot wires and a "neutral" wire. 110V breakers are rated for a circuit flowing from 1 hot wire to 1 Neutral. 220V breakers, on the other hand, are rated for the total current flowing through it's internal contacts between the two hot wires.
If you used a 220V 20 amp breaker to power 2 110V loads with power flowing from the breaker through the load to neutral then yes, you could have 20 amps on each leg because 20 amps is all that would be flowing through the contact for that leg. But if you're running a 220V breaker, then you're measuring current leg to leg and a 20 amp 220V load is causing a 20A flow through "BOTH" contacts. If you want to visualize it as DC you can think of it as flowing out one contact, through the load and then back through the other breaker contact to the other leg, where the 110V load would only be out one contact through the load then on to the neutral wire.
   / Scored a welder. Is it any good? #59
I have been told before that you could use 2 20amp breakers to make 40amp 220, as long as you connect the switches, so they trip together and you dont single-phase whatever your hooked to with 110v power.
You were told very wrong!
A 40 amp circuit uses a "twin" 40 amp breakers. You can substitute a pair of 40 amp single pole breakers and connect the levers together so that an overload on either leg will trip both breakers.
Pat.
   / Scored a welder. Is it any good? #60
My truck has a 130amp alternator and is connected to the battery with a 6ga wire and I can drive all day long and the wire doesn't melt.
It is very unlikely that your alternator puts out anywhere near 130 amps for more than a small fraction of "all day long."
If you put on enough driving lights and such you may be able to pull enough current for long enough time to experience melting the insulation off your alternator leads. Alternatively yo may be able to melt down the alternator.
Think duty cycle. I crank the engine of my diesel truck. I have two each 100 AH batteries in parallel. They supply oodles of amps from the battery to the starter (briefly.) Then after the engine starts the alternator supplies many amps to the battery but on a declining curve as the battery recharges. In a very few minutes the alternator output is quite low unless I am running lots of lights and stuff.
Pat
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
MASSAGE CHAIR (A58214)
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
