Scored a welder. Is it any good?
   / Scored a welder. Is it any good? #82
Kebo, you have the right idea, but you're a little off the mark. 120 volt AC doesn't swing + and - 120 volts. That figure 120 volts should read 120 volts RMS [Root Mean Square].
Simply put, 120 V DC = 120 V RMS A-C. The light, heat and power that a 120 v DC source delivers are identical to a 120 V RMS source. However the peak value of a 120 v A-C is 1.414 x the RMS value of 120V, that is its 169.70562 volts, rounding off to 170 volts + and - peaks. ;)
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2023 yamaha (A55758)
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
