Schematic of Cold Start Circuit
   / Schematic of Cold Start Circuit #11
Diesel's have higher combustion chamber temperatures and higher EGT with advanced timing. Gassers run hotter with retarded ignition timing. The thermistor heats up and reduces current supplied to the injection pump which retards the timing advance to reduce NOX stack emissions. When jumpering out the resistor so the injection pump to obtain full advance when warmed up. Cold starting will be improved. cold driveability improved and reduction of cold operation exhaust "smoke" occur with advanced timing.
As for cold weather starting. Plug in the block heater and hold the clutch down while cranking.
PALLET OF MISC BOAT MOTOR PARTS (A58374)
PALLET OF MISC...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58216)
2014 TIELKE...
SKID STEER MOUNT FORKS (A52708)
SKID STEER MOUNT...
Toro Groundsmaster 4000D (A56857)
Toro Groundsmaster...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
