Sceaming hydraulic noise.
   / Sceaming hydraulic noise. #1
fixthetractor
Branson 5835r
I have a Branson 5835r. It has been a very good tractor. However, sometimes while tractor is running and in the neutral position a screaming noise happens. I assume it is hydraulic related. To make the noise stop I turn the tractor off and immediately started it again. Does anyone have any idea what is happening? And how to prevent it from happening
   / Sceaming hydraulic noise. #2
Sorry to hear about your trouble with your 5835. I've been looking at buying that very tractor. If/when you find the solution to your issue, please keep us up to date.
   / Sceaming hydraulic noise. #3
Possibly try lowering the 3 point hitch a little to see if the noise stops. Chance that feed back link is borderline on adjustment so it randomly thinks the 3 point needs to raise a little more.
   / Sceaming hydraulic noise. #4
Could the sound be from the relief valve opening due to dead headding? I've had that happen when one of the remote levers gets stuck out of the neutral position.
I recently noticed when the noise starts, if I throttle up the engine for a short second the screaming stops.??
2025 CATERPILLAR 305CR EXCAVATOR (A60429)
2025 CATERPILLAR...
UNUSED IRANCH IRLB MINI HYD 4IN1 BUCKET (A60432)
UNUSED IRANCH IRLB...
2007 Heil Heavy Duty Aluminum Tank Trailer (A61306)
2007 Heil Heavy...
Adams 350T 10T Tender (A61306)
Adams 350T 10T...
2020 CAT 308 (A53317)
Deere 310SK (A57148)
