scarifier
/ scarifier #1
mrmikey
Elite Member
Nova Scotia, Canada
Iseki TM3160
Just finished building a scarifier and attaching it to the ole tractor.
The angle that the pins attach to is 3 x 3 x 3/8, main frame is 3 x 3 x 1/4 tubing, the pipes that go thru for the teeth to go thru is 1 1/2 sch40, teeth are 1 1/2 dia, diagonal brace is 2 x 2 x 1/4, flat bar is 3 x 3/8.
The tray is for cement blocks for ballast, find them easier to work with that buckets or barrells. At 40 lbs each I've got 4 on my back blade it it works great.
I don't think she'll haul all 7 teeth thru really packed soil or a lot of roots, if not I can remove whatever teeth I have to as they're bolted in.
No comments on the painting, I wouldn't have bothered as I dispise paiting but my daughter always hassles me if I don't paint projects.
While I was making things I cobbled up a sway linkage. Sick and tired of the blade moving side to side.
Just some 1/4" chain and a couple of pad eyes I welded 5/8 bolts to to go thru the arms at the front and a couple of turnbuckles I had.
I made this over the winter.
It was a pain in the backside having to fasten the two torque chains as well as the lock sleeve on the pto pump, always seemed to be tight and semi-stuck. I removed the chains and the lock collar, drilled and bent a piece of 1/4" plate. Now the pump just slides on the pto shaft with no lock and I just drop the bolt thru the trailer hitch holes and I'm good to go.
.....Mike
/ scarifier #2
Great job, but have you tried it yet?? Seems like unless you have down pressure on your lift, or you add lots of weight, that it would not dig very deep. There's no angle (or teeth really) on the tips of the scarifiers, so nothing to really force it downward when it's pulled. Course, I could be all wrong and it may dig very deep. Let us know how it works.
Oh yeah, I wonder about the chains for cross tension, never have seen that done before. That should keep it from swaying, but seems like it may need to flex a little bit from side-to-side whenever it hits something solid?
/ scarifier
Haven't tried it yet, have to wait for the ground to dry up a bit.
I intend to add cinder blocks to the tray to give it some down pressure. I did put a slight bend in the teeth so it should try to dig....I hope LOL. The bottoms are cut at a 45ー angle so the point load should make them dig in.
They're not singin' tight, if I push sideways on the end of the framework it'll move...ohhh a couple of inches give or take. I agree, I didn't want it solid....Mike
/ scarifier #4
I am impressed! You must have yourself quite the shop to work in:thumbsup:
Keep us informed on how well it works. If you think that It is not digging enough you can turn in the third point to angle the teeth, with a box blade if the third point is shortened it digs deeper so that should work there with your back scratcher
/ scarifier #5
Nicely done! :thumbsup:
/ scarifier #8
I am confused by what the cross turnbuckles are doing other than keeping the little bit of slop out of the ball joints to pin attachments. That would have been easier to accomplish with just some shim washers between the pins and the lift arm balls to take up the little bit of slack . It looks like the arms will still sway as much as the stabilizer bars or chains will allow. What am I missing on this?
I also think the pipe is going to be a weak point and will likely need to be replaced with solid steel. Pipe is pretty easily bent.
Let us know how it does when you get it in the ground.
/ scarifier
Thanks for all the compliments/comments guys, much appreciated.
My comercial (cheap) box blade has 1/2 inch x 3 inch scarifiers and I pretzeled one when it caught a good root.
Origonally I was going to make the teeth from 3/4 x 3 flatbar which would have been easier, making the teeth part that is. The reason I didn't is that it would have been more work making the pockets for them to fit in. I'd have to make a pocket that was slightly oversize so they wouldn't bind up. The 1 1/2 bar and the 1 1/2 pipe combo had enoughslop so that seizing up isn't a problem.
I looked around work for some old actual scarifier teeth from graders but nothing was around. They have holes down the center so you can move them around, would have been the cats behind.
As for bending, I still think they could be bent and not all that hard to do neither, I'll just have to watch where I'm going (yeah right GBG).....Mike
**EDIT
You must have been posting when I was replying Gary
I had more than a little bit of slop, when I was moving snow this winter the back blade would move well over 6" side to side. Wasn't bad except when you were trying to clear close to a car or some other obstical. I was concerned that the constant banging side to side would eventually bend or break something more so than a constant push pressure would.
Only way I can think to explain it is the geometry of the chains. If you push the back attachment to the left, the chain that's attached to the bottom left side of the angle is going to pull on the right link close to the machine. Since there's little room to move it tightens up. same going the other way.
I didn't want to use washers as it's more pieces to lose and with the chains I can give it a bit of movement if I want or tighten it right up. Not only than, if you depend on the washers to stop side to side play you're getting a lot of leverage via the arms, 2' or so to the machine. With the the chains the only leverage is the distance from the chain to the machine, 6" or so.
Actually, I don't think washers would work because of the balls on the end of the arms and the machine end.
It is solid, 1 1/2" dia stressproof....Mike
/ scarifier #10
Hey, I need to borrow your new implement; where you located. :thumbsup:
/ scarifier #11
"I don't think she'll haul all 7 teeth thru really packed soil or a lot of roots, if not I can remove whatever teeth I have to as they're bolted in. "
What tractor are you pulling this with?
I ask because my 6 foot box blade has 7 shanks on it and if I do it just right, it stops my tractor (grand L5740) in a heartbeat.
As long as your shanks are, that's gonna be a load if you bury 'em.
Otherwise, great job. :)
/ scarifier
Not too far away, Nova Scotia LOL
20HP Jinma 4WD.
I'm expecting to have to remove some of the teeth. Saying that, the ground is very wet and 90% alder roots so they're not too deep.
If I could get there now I'm sure I could get the roots up no problem but the ground being wet works against me for moving around. I could get there but I'd be using most of my power getting around not to mention I have to travel over my lawn so I don't want to chew that up....yet....Mike
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A64279)
2013 CATERPILLAR...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2014 Dodge Grand Caravan Van (A61574)
2014 Dodge Grand...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2020 CATERPILLAR 262D3 SKID STEER (A64279)
2020 CATERPILLAR...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
