Scale Cat Twenty Two Dozer Ride On For My Son
   / Scale Cat Twenty Two Dozer Ride On For My Son
It's been a little while. Been busy with two kids. Speaking of which, I can't build a dozer for the one boy and not build something for the other.
So I've started on this.
I still have some design work to do but I can only get so far until I start buying parts so I can model them properly.
First up? Some axles. One is a GM 14 bolt full float axle and the other is from a 2wd S10. I have a plan to graft them together and will show more detail soon.
With this build, I may tend to post more details on my webpage (seen here). I've found that it lets me organize the build a little better and index the different stages. However, I won't forget about you all here and I will continue to update you all as the build moves forward.
   / Scale Cat Twenty Two Dozer Ride On For My Son #283
Another very cool project in the works!
   / Scale Cat Twenty Two Dozer Ride On For My Son #284
That was the coolest project ever. That will be a great heirloom piece for future generations.
   / Scale Cat Twenty Two Dozer Ride On For My Son #285
I see a loader build in the future. Gotta be able to fill the dump truck.
   / Scale Cat Twenty Two Dozer Ride On For My Son #286
Looking forward to following this also.
That is true. That could be a project that I work on with both boys.
Still probably a few weeks before I can start making sparks or chips in the garage. I have a pretty good idea how I'm going to meld the two axles together. In the end, it should look like this.
The center section, axle shafts and a few inches of tube will come from the S10. The spindles (and a portion of the tube) and the hubs will come from the 14 bolt.
You can read more details here. Caterpillar Twenty Two Replica Mini Dozer Build: Rear Axle
   / Scale Cat Twenty Two Dozer Ride On For My Son #288
Following..
   / Scale Cat Twenty Two Dozer Ride On For My Son #289
Looking forward to seeing what you come up with. How is the dozer holding up? How many hours do you have on it so far?
Hi Eddie. It's holding up pretty well. Just some oil leaks I have to fix. I think I put about 20-30 hours on it before I painted. We got so much snow that year. After I painted it, I installed an hour meter. I checked it last night and we put about 22 hours on it so far. Doesn't seem like much. We didn't get as much snow this year. And up until a few weeks ago, it seemed to rain every other day. So my yard was pretty soggy. And one of the tractor shows I was going to take it to in July was canceled because the field was so wet from all the rain. It's been an interesting summer. I plan to take it to the annual antique Caterpillar show that's being held this year in Wisconsin. I'm looking forward to that.
Knowing what I put into the dozer, I have a fair amount of work ahead of me with this dump truck. But if I plan ever better, it shouldn't be too bad. We'll see if I can finish this one.
Take care.
Ryan
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2017 Case CX145D (A60462)
2017 Case CX145D...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
