Scale Cat Twenty Two Dozer Ride On For My Son
   / Scale Cat Twenty Two Dozer Ride On For My Son #221
I vote for the the mini stack you have there. That looks cool.
   / Scale Cat Twenty Two Dozer Ride On For My Son #223
Mini stack
Scooter
   / Scale Cat Twenty Two Dozer Ride On For My Son #224
I'm looking for opinions on mufflers. I always wanted a stack out the top with one of those flapper caps (whatever they are called). Well, I have absolutely no room left. This is the stock muffler which I could keep but it's boring. Or I picked up this muffler and I'd mount it outside the engine compartment. Also, it should keep heat away from some things. I can't decide. What do you guys think?
Will you be removing the stock muffler and mounting the stack directly to the engine?
If so then stack with flapper!
You could go duals out each side; would sound saweet!
   / Scale Cat Twenty Two Dozer Ride On For My Son #225
It needs the stack. I don't know how you could have come much closer without it _being_ scale !! You mentioned the 10 and 20. Dad had both, 10 first but the steering clutches needed re-do so he got the 20. I always liked seeing the 10 idling and blowing smoke rings out that stack with the flapper wiggling.
Harry K
   / Scale Cat Twenty Two Dozer Ride On For My Son #226
Needs the stack:thumbsup:
   / Scale Cat Twenty Two Dozer Ride On For My Son #227
I think the stack came out the left side on a 22. If you put a couple of right angle bends in the pipe to bring it out the left side, you probably wouldn't need a muffler.
   / Scale Cat Twenty Two Dozer Ride On For My Son #228
Absolutely needs the stack and flapper.
   / Scale Cat Twenty Two Dozer Ride On For My Son #229
I used a muffler for a Ford tractor with an couple elbows that I bought at Fleet Farm and welded it together my self.
[/URL]
   / Scale Cat Twenty Two Dozer Ride On For My Son #230
Beautiful workmanship! I noticed a compound on top of a rotary table. The math to do offsets for points of rotation and cutter diameter comp takes some talent. Thank goodness CNC came along not long after I left tool & die school. Why not delete the pepper pot muffler, fab a simulated oil bath and then run the stack straight up through the hood? Or the air cleaner off a Ford 8N or NAA would be about the right size as well. For that matter you might be able run the exhaust down and then back up on the left size like the original. Some of the orchard models used louvered side panels which would hide it all.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
40 (A52708)
40 (A52708)
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
