SC2450 no crank.
/ SC2450 no crank. #1
Skyssx
Cleveland, Ohio
CCY SC2450
Pressure washing my SC2450 and changing up the implements today, I got stuck in a no start/no crank condition. I did a general wash of the tractor and FEL, a detailed wash of the BH. I backed into a spot, dismounted the BH and set it onto a stand. I shut down the tractor to disconnect the hydraulics and could not get it to start afterwards. I have tested the brake switch, seat switch and PTO switch OK as well as the wiring harnesses thereof. The fuel cut solenoid is operating correctly, the starter is just not engaging at all. The starter fuse is intact. Any ideas?
/ SC2450 no crank.
The pressure washer knocked out the starter enable line. Small green plug on the bottom of the starter assembly. Fixed.
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2001 Kubota L3010 (A64126)
2001 Kubota L3010...
Alligator Statue (A64127)
Alligator Statue...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
