SC2450 no crank.
/ SC2450 no crank. #1
Skyssx
Cleveland, Ohio
CCY SC2450
Pressure washing my SC2450 and changing up the implements today, I got stuck in a no start/no crank condition. I did a general wash of the tractor and FEL, a detailed wash of the BH. I backed into a spot, dismounted the BH and set it onto a stand. I shut down the tractor to disconnect the hydraulics and could not get it to start afterwards. I have tested the brake switch, seat switch and PTO switch OK as well as the wiring harnesses thereof. The fuel cut solenoid is operating correctly, the starter is just not engaging at all. The starter fuse is intact. Any ideas?
/ SC2450 no crank.
The pressure washer knocked out the starter enable line. Small green plug on the bottom of the starter assembly. Fixed.
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
Gravity Flow Wagon (A64127)
Gravity Flow Wagon...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
