SC2450 no crank.
   / SC2450 no crank. #1
Skyssx
Cleveland, Ohio
CCY SC2450
Pressure washing my SC2450 and changing up the implements today, I got stuck in a no start/no crank condition. I did a general wash of the tractor and FEL, a detailed wash of the BH. I backed into a spot, dismounted the BH and set it onto a stand. I shut down the tractor to disconnect the hydraulics and could not get it to start afterwards. I have tested the brake switch, seat switch and PTO switch OK as well as the wiring harnesses thereof. The fuel cut solenoid is operating correctly, the starter is just not engaging at all. The starter fuse is intact. Any ideas?
   / SC2450 no crank.
The pressure washer knocked out the starter enable line. Small green plug on the bottom of the starter assembly. Fixed.
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
