SB200 chute not rotating
/ SB200 chute not rotating #1
Listonk83
Wilmington ma
Bobcat s130
I have an 09' S130 with the 7 pin connector. The auger and propeller are working but I can't get the chute to rotate or the deflector to go up and down. Are the controls for the deflector also on the right hand stick? Also the high flow switch will not turn on only the aux switch. Thanks,Ken
/ SB200 chute not rotating #2
OK so you have a Bobcat hydraulic drive S130 snow caster.
Have you checked the fuses/circuit breakers??
I would like you to get an aerosol(spray can) can of wire drier
and a tube of dielectric grease for the plug.
1. Spray some wire drier on the plug ends-including the one
that plugs into the skid steer loaders s electrical system and let it dry.
2. rub some of the dielectric grease on the female portion
of the plugs and then put the the connectors together and the
connection should be fine then.
If the above does not work you may end up having to take the snow
caster to your dealer to have the wiring replaced.
I have not checked the fuses / circuit breakers I didn't even think of that. I did try the dielectric grease on the connections but still nothing. Hopfully it is just a fuse like you said thanks Leonz
/ SB200 chute not rotating #4
I'm having the same problems. Did you have any luck getting it working?
