TnAndy
- Joined
- Aug 9, 2013
- Messages
- 2,000
- Location
- East Tennessee
- Tractor
- Yanmar LX410...IHI 35J excavator Woodmizer LT40
I bought a Woodmizer LT40 in 1991, and totally recommend them. The models have changed numbers some....mine has the 34"x21' capacity, and is a "manual" mill. (has the power drive of the saw head, electric up/down of the head and in/out of the blade guide) Unless you plan to saw full time, the manual model is completely adequate for part time use.
I have around 60ac of timber and have been selectively cutting for 30 years now, along with buying logs when I can or simply getting them for free (lot of times) if I'm willing to go get them. With your 250ac and a willingness to work at it, you'll find a ton of use out of a mill, AND as Rob says, you can sell the mill down the road if you decide to. I probably will in another 20 years.....or so......
I also started with an Alaskan, building my first shop building with it.....and it changed my world to go to the Woodmizer. You'd probably be amazed at all the things you'll find to build once you have a supply of inexpensive lumber. I've built all kinds of sheds, a new shop, 3 rental houses (not on my property), buildings/barns for other people and furniture galore.
Sawdust isn't much of a problem, but slab wood can be if you don't use wood for heating....I do heat with wood, but still end up piling a lot of mine up and simply burning the pile from time to time.
Cutting a 30' beam on a 21' mill....it can be done !
Cut tapered lap siding....I use it everywhere on my buildings.
Four 12' logs out of a 24" DBH poplar tree = 100 2x4s and 90% of them better than anything you'll find a Big Box store.
My shop...100% cut off my place.
Hog housing:
Chicken housing:
Firewood housing (aka 4 cord sheds)
Hog housing:
Chicken housing:
