Sawmill. What do I need to know.
   / Sawmill. What do I need to know. #21
I bought a Woodmizer LT40 in 1991, and totally recommend them. The models have changed numbers some....mine has the 34"x21' capacity, and is a "manual" mill. (has the power drive of the saw head, electric up/down of the head and in/out of the blade guide) Unless you plan to saw full time, the manual model is completely adequate for part time use.
I have around 60ac of timber and have been selectively cutting for 30 years now, along with buying logs when I can or simply getting them for free (lot of times) if I'm willing to go get them. With your 250ac and a willingness to work at it, you'll find a ton of use out of a mill, AND as Rob says, you can sell the mill down the road if you decide to. I probably will in another 20 years.....or so...... :D
I also started with an Alaskan, building my first shop building with it.....and it changed my world to go to the Woodmizer. You'd probably be amazed at all the things you'll find to build once you have a supply of inexpensive lumber. I've built all kinds of sheds, a new shop, 3 rental houses (not on my property), buildings/barns for other people and furniture galore.
Sawdust isn't much of a problem, but slab wood can be if you don't use wood for heating....I do heat with wood, but still end up piling a lot of mine up and simply burning the pile from time to time.
enhance
Cutting a 30' beam on a 21' mill....it can be done !
enhance
Cut tapered lap siding....I use it everywhere on my buildings.
enhance
enhance
Four 12' logs out of a 24" DBH poplar tree = 100 2x4s and 90% of them better than anything you'll find a Big Box store.
enhance
enhance
My shop...100% cut off my place.
enhance
Hog housing:
enhance
Chicken housing:
enhance
enhance
Firewood housing (aka 4 cord sheds)
enhance
   / Sawmill. What do I need to know. #22
Hay housing (cattle stalls underneath)
enhance
Round bale housing:
enhance
enhance
Vegetable housing....arches made of dead green white oak.
enhance
enhance
enhance
Renter housing
enhance
enhance
enhance
Bird housing :D
enhance
Dining room table for a buddy of mine's new house (which he cut all the framing for using my mill I lent him for a few months)
enhance
enhance
Nah, if you have a sawmill, and run out of projects, it's ONLY because you just ain't looking hard enough ! :laughing:
   / Sawmill. What do I need to know. #23
Andy, I really enjoy seeing your pictures and what you have accomplished!!!!!
   / Sawmill. What do I need to know. #25
Thank you Eddie. I still drool over that gazebo of yours.....true wood art man !
   / Sawmill. What do I need to know. #26
I have been impressed with Norwood mills, so check them out. I feel like WoodMizer is the best, but they are also the most pricey.
"These days", the only thing they are the BEST at, is advertising!
SR
Andy, thanks for the post. Those are some of the things I'd like to do. I'd also like to do a big gazebo but it would not be anything like Eddie's. I'm not that gifted.
Also good point about commercial lumber. The quality these days is awful. My back porch steps were made of (yellow) treated lumber. Installed by a professional contractor. They were literally rotten and falling iapart in less than 6 years. No special circumstances or unusual exposure. Some sloppy work but that's it. With regular nont-treated 2x4s, 2x8s etc, I spend forever in the big box or lumber yard sorting through the pile just to find stuff that isn't twisted, splintered or covered in bark.
There is a deer stand in my creek bottom that has been there for nearly 20 years. Just a ladder with a seat. It was made of the wet green treated lumber. It is in contact with the ground and is under water 3 -4 times a year when the creek floods. It is still solid.
   / Sawmill. What do I need to know. #29
Rob has a Norwood mill iirc. I've had the band mill itch for a long, long time and never really understood why Woodmizer is so popular. A friend has one and is constantly having electrical "issues" and the cantilever design has always been a big "why" for me, one "leg" is inherently unstable and not long ago WM introduced a 4 legged mill. :confused3:
I'm not knocking WM and a lower end manual mill is not all that electric motor, switches, wiring and solenoid dependent and for me, I just don't understand the single beam and cantilever design from an engineering standpoint, just like when Chevy switched to holding up a 4x4 truck with torsion bars:confused2:, just not for me but there are plenty of folks with WM saws and GM trucks.
   / Sawmill. What do I need to know. #30
Which brand would you get if you were buying one today?
My mill is a Lumbermate 2000, it has been stone reliable,
And has no problem staying dialed in, I can saw out veneer if I want,
I have looked at most of them, and milled lumber on many of them. As to what brand I would buy, depends on what category of mill I was buying, but in a manual mill, I'd be looking HARD at the Norwood and Ez Boardwalk brands...
SR
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
43029 (A51691)
43029 (A51691)
QUICK ATTACH COUPLER (A57192)
QUICK ATTACH...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Mechanics Crane Truck (A55852)
2015 Ford F-750...
UNUSED FUTURE MISC HYD HOSE BUNDLE W/ FITTINGS (A57193)
UNUSED FUTURE MISC...
