Satoh Tractor
/ Satoh Tractor #1
Sonny580
Central Illinois
several kinds and sizes
Just got this thing and trying to figure out the approx. year and if they are any good or not!
Satoh (Bison,--I think) S650G gas engine, I have the steering gear parts with it to put the steering back together!---The motor runs like a banshee and rest of tractor looks well made and tight, so am I wasting my time on this unit or should I continue with it??---I really like all the features it has!---diffy lock/ hi-lo trans/3-pt hitch/ FAST lift hyd. system/etc! thanks; sonny
/ Satoh Tractor #2
My experiences with Satohs is that they are decent tractors. It's like a lot of things in life, as long as they're used within their design limits and basic maintenance is done they are fine. I do not have any direct experience with the S650G though. The main thing is that it doesn't really matter what others think of them, as long as *you* like it which it sounds like you do. You'll always find people that will like, dislike, or be indifferent towards any particular thing.
/ Satoh Tractor #3
Sotah is Mitsubishi.
I run a MT180D and can assure you that they are tough well made machines.
Drawback might be if PTO is not standard as some rotated wrong way and used smaller shaft but a converter (reverser) is available.
Your gasser would be a Mazda based engine.
Couple of members on this site do support the Sotah and Mitsu tractors.
/ Satoh Tractor #4
True, however my understanding is that Satoh was an established tractor company spanning quite a few years of history before Mitsubishi acquired them. I know that the S373D I have was influenced very little by Mitsubishi other than some decals from it's pre-Mitsubishi ownership. It appears Satoh chose Mitsubishi engines for some of the tractor lines as did other tractor companies such as Iseki.
/ Satoh Tractor #5
The Satoh 650G pto is US. standard 1 3/8" and rotates correctly. They have a mazda motor in them, I believe. I have a friend that has a nice one, for sale/ loader ; new rims,tires running for fair money, if your interested.
/ Satoh Tractor #6
Size wise are these things more like the S373/MT372's or like a Ford 9/8N?
/ Satoh Tractor #7
The S650G is more like the 8N, but is not quite as big or powerful, but close. It is a 22 PTO horsepower tractor with 11.2 x 24 tires out back. The 8N is a 23 or so PTO horsepower machine with 10-28 rear tires. The S650G weighs about 2100 lbs, where the 8N is 2400 lbs, both unballasted. The Satoh has an advantage in gearing, having high and low range for 6 forward and 2 reverse speeds, vs 4 forward and 1 reverse speed for the Ford. For 21 horsepower of output at the PTO, the Satoh will burn almost 3/4 of a gallon less.
I would say the S650G is a better machine than the 8N, with more gears, better economy, differential lock, etc. On the other hand, the sheer prevalence of the N series of tractors makes them serviceable and maintainable in a way none of the Japanese machines are.
/ Satoh Tractor #8
Sonny, I have one...had her for 4 yrs. Tough tractor, parts are tough to get, but I have come a long way in building a list of part numbers and sources. Let me know if you need anything or have questions.
Raf
/ Satoh Tractor #9
Raf
Hello Raf, just wondering where you would get engine parts for your tractor. I need head gasket set, piston ring set and rod and main bearing set. Cannot seem to track down anything. Any help would be greatly appreciated. Thanks, Tanar.
/ Satoh Tractor #10
What model Satoh tractor is it?
/ Satoh Tractor #12
Raf
hi my name is jaco i live in south africa and like to know where can i get parts 4 my satoh DST90
/ Satoh Tractor #13
hi my name is jaco i live in south africa and would like to know where can i get parts 4 my satoh DST90 tretor?
/ Satoh Tractor #14
Hi all, and a special thanks to the Moderator/Webmaster who created this site;)
I joined this site to also let WWW know that I have Spin-on OIL FILTERS (EQUAL TO FRAM PH2865A) surplus to my needs to
suit SATOH TRACTOR S550G, S650G with 25hp gas engine .......have been using these filters for over 35 years without 1 issue so know they're "bullet-proof"
I'm located in Melbourne Australia, but happy to send filters worldwide if I can make a dollar profit. Postage Aust-wide is $10; guessing $20 for O/s ?
These filters are $40 from our Repco parts store, but I'm happy to take whatever you reckon's a fair offer:)........up to you.
my email is agrademechanic@hotmail.com
My Westwood Garden Tractor has a single cylinder LOMBARDINI DIESEL for which I'd be happy to trade any parts that suit this 6LD360V (VERTICAL SHAFT) in trade for these filters
For the Technical-minded, these superb "Karinna" Filters have an Anti-Drainback Valve and also a By-Pass Safety Valve(20psi) and its Sealing pad has an OD of 85mm, a Screw thread of M20x1.5, a body-height of 83mm and OD of 91mm
Bobcat T66 (A60462)
Bobcat T66 (A60462)
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
Unverferth 632 (A64119)
Unverferth 632...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
