satoh s650g 27hp
/ satoh s650g 27hp #1
coaldog99
satoh s650g
tractor overheats sometimes some air bubble in radiator whats wrong
/ satoh s650g 27hp #2
You may have air trapped in the block. Try parking with the nose uphill to allow the bubble to work its way to the radiator. That's the cheap fix. You may also have a head gasket allowing compressed fuel air mixture into the coolant. You could also have a cracked cylinder. You can also check in with Valley Power To reduce over heating be very sure the radiator fins are clear, too. The best method seems to be air or water pressure from the engine side forward.
/ satoh s650g 27hp #3
Your issue could be any number of items. You did not indicate if the coolant remains full or not nor how fresh the coolant is.
Therefore it is hard to give anything but general opinions.
If you loose coolant it could be as simple as a leak that could explain overheating and air bubbles.
Or it could be a much more serious condition such as a blown head gasket, which also explains overheating and bubbles.
Of course these are only in my opinion the extremes on conditions that could cause your symptoms and far from an exhaustive list.
Best of luck
/ satoh s650g 27hp #4
Anyone ever attempt a electric rad fan conversion?
