Satoh s370d beaver.
   / Satoh s370d beaver. #1
james waters
whitesville,ny
yanmar 1500
Just got this tractor. Battery was bad put a new one in it and it seems to be a hard starter. I finally got a pull start and tractor seems to run great. Question is how to make it start easier. There is a glow plug indicator on dash that lights up after key is turned backwards for several second. Could the glow plugs be bad. Also i see fuel leaks in the return line at top of injectors. What else can i do. How do i time a deisal and what should the compression be.
   / Satoh s370d beaver. #2
I will try to help. I do have a beaver but haven't started it in a few years. I do remember it did not like cold weather very much. I would hold the plugs on for about 30 seconds hit the starter and if she didn't hit fairly quick, I would cycle glow plugs for another 30 seconds. Sometimes it would take three or four tries, but it always fired off. As far as the fuel leaks, I would repair those as soon as I could. Timing should not be an issue. I do have a service manual somewhere and could look up compression for you providing I can find the manual. Mine was starting to burn a little oil but not bad. I broke the output sector shaft on the steering box and that is why I parked it. Great little tractor! Enjoy.
Hey thankyou. I ordered the oem service manual
Also when i got home i turned on glow plugs and when the indicator was clear i counted 30 second and after some cranking it took off. So that was a big win win there. So now i will try usi g the glow plugs more then once to see if i can start it easier( less cranking). It does run great now to fix the little things here and there
   / Satoh s370d beaver. #4
Great! Glad to hear you got it running. One day, I am going to get mine going again and will need your help. :thumbsup:
Thank you again and question ever read anything about adding power steering to the beaver
   / Satoh s370d beaver. #6
Have a Mitsubishi MT180D, very similar to your s370d, good tractor.
IMHO ranks with Kubota quality.
As to cold starts, mine is plugged in with block heater and I also re cycle the glow plugs when it is very cold.
I am also in the process of adding power steering (when I find the time) and have most components on hand to do so, (LOL like 3 years now).
   / Satoh s370d beaver. #7
The Mitsubishi needs to be glow plugged even when it is warm out. I can supply the major components to add powersteering.
   / Satoh s370d beaver. #9
email me for pricing.
   / Satoh s370d beaver. #10
Compression should be 455psi, but it should start and run fine down to 375psi ive been told.
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
2002 Mack DM690S Roll Off Truck, VIN # 1M2B209C32M028771 (A51572)
2002 Mack DM690S...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
KMC 5610 (A53084)
KMC 5610 (A53084)
