Satoh S-650G won't start
/ Satoh S-650G won't start #1
AcmeDave
Satoh 650G, Long 2610, Kubota 3800
My Satoh has a 4-cylinder gas engine. Over the past year I've replaced:
- Fuel lines, filter, fuel pump, carburetor
- Spark plugs, wires, points, condenser, ignition coil
Each time it ran a little better or worse. The last thing was the coil which did wonders. Now it won't start at all. Not even a pop with ether.
I find a spark on each cylinder. The timing is right on. Good gas flow. Well charged battery.
Not even a cough! What am I missing???
/ Satoh S-650G won't start #2
Have you tested the compression? Low compression may be caused by bad rings, valve adjustment or burned valves.
Checked compression: A solid 20 psi on all cylinders. Head gasket?
