Satoh Bison s650g problem
   / Satoh Bison s650g problem #1
SatohBison1987
Satoh Bison S650g
Alright here is my deal, everything is fine with the tractor except that it wants to bog down when driving up hills and even on flat ground sometimes even if I run the RPMs high. I'm really not sure what the deal is I have changed the plugs, wires, etc. Any ideas will be greatly appreciated.
Thanks!
   / Satoh Bison s650g problem #2
I think I would suspect a fuel pressure/ filter issue based on symptom may want to inspect the fuel supply hoses and lines for splits or cracking etc. also. Good luck
Thanks so much..That's what I will do! See what happens
   / Satoh Bison s650g problem #4
Thanks!
You might check the governor
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2025 TMA Attenuator Truck (A52377)
2025 TMA...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
Utility Trailer (A52377)
Utility Trailer...
