Oil & Fuel Satoh 650G - Oil Leaking from Fill Cap?
   / Satoh 650G - Oil Leaking from Fill Cap? #1
ntventure
Pittsburgh
Satoh 650G
I recently had tractor in for service. One of the things they did was steam clean the frame and put on a shifter boot (there was lots of oil caked up in this area). Today I used tractor for the first real work since I got it back and noticed oil leaking from around the oil fill cap. See the attached pic.
Not blaming the service company - this problem had been occurring before obviously I just couldn't tell from where the leak was coming.
Do I just need to replace the oil fill cap? Or is this indicative of another (larger) problem. Thanks!
   / Satoh 650G - Oil Leaking from Fill Cap? #2
Might just need a seal, or it is possible the gear box is overfilled.
   / Satoh 650G - Oil Leaking from Fill Cap? #3
Is there a vent on that case? Maybe stopped up & building up pressure.
   / Satoh 650G - Oil Leaking from Fill Cap? #4
There should be and "O" ring in the fill cap but if the transmission is too full the oil will come out somewhere. There is a plug on the left side of the transmission about the same level as the foot rest that indicates proper fill level. See attached diagram.
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
