Oil & Fuel Satoh 630 D - fuel problem
/ Satoh 630 D - fuel problem #1
LarryP
I was driving my Satoh 630 Diesel and it just quit. I pulled the fuel lines off, at the top of the block, and turned over the tractor and no fuel squirted out. Next I removed the injector pump, which looked fine, and then looked inside the engine block and all parts were turning.
Any suggestion?
/ Satoh 630 D - fuel problem #2
Did you try opening the bleed screws? If there is no fuel there your filter may be stopped up. Don't take the lines loose from the injectors until you know you have fuel going to the pump, bad for the pump turning it with no fuel in it.
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
