SATOH 550G problems running NEW MEMBER NEED HELP!
/ SATOH 550G problems running NEW MEMBER NEED HELP! #1
charlesfl
First of all, I am glad to see there is a support group for tractors, and this one looks really great. With that said, let me see if anyone can help....
I have acquired a 1970's model Satoh Elk 550g. It is in decent shape, but well used. It will need a great deal of work to become a reliable daily use unit, but I would like to begin by getting it running properly. This afternoon I put a battery in it, and had a rough time getting it to crank. After changing the cables and cleaning multiple connections, I can get it to crank with no problems. The gas tank is shot, so I ripped it off, and rigged a gas container as a temporary fuel supply solution. All of the throttle linkage was seized up, so I lubricated everything and appear to have it working fairly well. Here is the deal- I can get the thing to start, after cranking it for a minute or so, IF i put gas in the carb. It runs that gas out, and then that is it. One time, I seemed to get it to run off the fuel in the fuel tank as well. If I pour more gas in the carb, after another minute of cranking, I get it to run again for a few seconds.... Do I need to get this carb rebuilt? Anything else I should do? I don't want to pour money into this machine and then find out there is an array of other problems.
Any feedback would be greatly appreciated!
Thanks!
/ SATOH 550G problems running NEW MEMBER NEED HELP! #2
We've corresponded privately about this. Here's an update for the readers. At my suggestion you discovered it had no fuel pump and it doesn't work well as a gravity feed. Install a low pressure electric pump or the original mechanical pump because it is starving for fuel.
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
2012 International WorkStar 7400 Service Truck, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
CAT CB34 (A60462)
CAT CB34 (A60462)
Dual Rear Wheel Axle (A59230)
Dual Rear Wheel...
