sanding disc grit
/ sanding disc grit #1
M E Cook
SE TN
ls tractor
What grit are you guys using on your disc and belt sanders for general purpose metal work and what speed is ideal for the machine to run
/ sanding disc grit #2
For rough work, like removing paint, and mil scale. I use a 36-grit sanding pad. If the item is going to be painted, I use 80-grit. The small grinder runs around 12,000-RPMs. The large bench sander runs at 2,500-RPMs.
/ sanding disc grit #3
80 grit is what belts we run at work. I have no complaints. Mainly used for knocking edges off of parts that come out of the bandsaw. And touching up drillbits.
If I was wanting to do any serious shaping or hogging material, I'd want something courser.
/ sanding disc grit #4
60 for me on a disc. Anything more coarse I go back to a regular grinding wheel like an A24. Or Flap discs in assorted grits from 36 - 120. Great for lawn mower blades and general sharpening. Belt sander I use 40 0n the disc and 60 on the belt. I'm sure everyone has their favorites due to the vast amount of tasks at hand.
/ sanding disc grit #5
36 for smoothing welds and on the 12" disc sander for shaping. If finish matters take out the swirl marks with 80 and go over it with scotchbrite rolocs in the 2" air sander.
/ sanding disc grit #6
It really depends on what you want as far as a smooth finish goes...regardless of how course of grit you start with...as long as you have progressively smaller grit...using "wet or dry" silicon carbide media you can take just about any metal (and many other materials)...down to a mirror finish...
a little off topic but "hard" plastic tractor/equipment lever knobs that have been faded by the sun/elements can be restored to their original shiny look by sanding/polishing with progressively smaller W/D paper...for most faded knobs try starting with 100 grit (keep all grits wet, rinsing often) down through all the available grits until it's as shiny as you want to go...generally 600Grit will be enough to look new...but you can go on down all the way to "mirror finish"...
Caveat>>...this will not work on malleable knobs...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59912)
2007 FREIGHTLINER...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
