SANDBLASTING
/ SANDBLASTING #23
I think I read all the posts but didn't read any better living through chemistry thoughts. High pressure sprayer assisted by some good paint remover can work miracles. For rust, some phosphoric acid or swimming pool acid, maybe even electrolysis if the rust is bad.
I do like the pressure washer/sand mix and will be buying the suggested attachment from Northern Tool soon.
/ SANDBLASTING #25
I got into sandblasting about 10 yrs. ago.Built alot of the eqipment myself.
I used to be into restoring garden tractors.Anyway,it is a filthy job.You'll
have sand in your ears,hair,eyes,mouth( and alot of other places that we wont talk about) for about three days.BUT,it does do a great job,no doubt
about it.
But you gotta be carefull when using these things.The cabinet models are pretty safe as everything is contained.But the pressurized ones that you use outside,they are nasty!!Make sure you wear heavy clothes and gloves.I use coveralls and the full length welders gloves.Also,a GOOD resperator to filter the air.I beleive you can get what they call "Siliconosis" from getting too much of the dust in your lungs,bad stuff.I bought a "sandblasters" hood when i started doing this stuff but didnt like it so i started using a old welding helmit
with just the clear lens in it.Gotta have extra lenses as they only last about ten minutes before they are "frosted",and you cant see.If you get the right kind of helmit,you can fit a resperator underneath.I fix up an "apron" on the back of the helmit to keep the sand from going down my neck.
The compressor i use is one i built with a 4-cyl. 2 stage pump,driven by a 18 horse Kohler twin engine,so its portable.Got an 80 gallon tank underneath the pump and engine,mounted on a VW Rabbit rear axle.
Fairly serious compessor for the average guy.But if you want to get it done and you dont want to take all day,you need at least that.The blaster
i use goes through about 10 pounds of sand in a minute and it does make that compessor work.Its pumping about 75% of the time i'm blasting.It does take a good size compressor to run a decent size blaster.If i remember right,
the manufacturer for the compressor pump(Speedair),recommends 75%
max. pumping time,with a 25% cool down time at least.Otherwise,you'll
eventually burn the compressor up.
Anyway,thats just to give you an idea whats involved.If its just a one time thing,i would take it to somebody who is set up to do it,and pay them
for the work.Its just alot less hassle and would prob. be cheaper in the long run. digger2
/ SANDBLASTING #26
What Digger says is right. and some sands are very toxic, ya have to wear a ( bee-keepers hood ) and NO pockets at all
Trust us, its a learning experience
/ SANDBLASTING #27
john_bud said:
Probably the least expensive is to take it to a SB place and have them do it. Probably looking at 1 hour worth of work including set up and such. Probably 75 bucks.
jb
I tried sandblasting my Deere 655 mower deck (50" I think) with a 10 gallon blaster and eventually gave up. A local shop blasted and powdercoated it for about $70 (they had standard rates for things like mower decks, furniture, etc).
Given all the time and hassle I went through, $75 was the best bargain I've found this year. When the blaster worked it was fun, but it just wasn't worth the hassle.
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
