Sandblasting question
/ Sandblasting question #21
Any fine and "DRY" sand will do.A good chioce is "00" sand, it will leave a smooth surface,you can buy it at masonary supply store at 5$ to 7$ for a 55 lb bag.A few have suggested Black Beauty it works great if you are not looking for a smooth surface ( it leaves small dimples on the metal). A few other post I read had issues on how slow is to sandblast and all I can say is: controll of the flow of sand is the key to speed while sandblasting. If too much sand gets to the tip you will waste a heap of sand and no rust is removed. I used a sandblaster from SEARS and it has a simple ball valve at the bottom of it to controll the sand.Adjust it so that you don't see the sand but the rust is getting removed. It works like a charm. <font color="red"> </font> SAFETY: sandblasting will release silica in the air, breathe enough of it and silicosis is a good bet. A good respirator is a must (not a paper mask). Sand will also sting like fireants,long sleves, safety gogles and a face shield are a must. HAPPY SANDBLASTING /forums/images/graemlins/grin.gif
/ Sandblasting question #22
OkieG, Interesting observation you raise. I do not know what incidence rates for silicosis are for various areas, but I do know that there is more silica in the air in some places than others - just as there are a few areas in North America where there are higer concentrations of asbestos fibers in the air. Asbestos is a naturally occuring mineral too. So, to your point, just because it is "natural" doesn't mean it can't kill you.
/ Sandblasting question #23
<font color="blue"> So, to your point, just because it is "natural" doesn't mean it can't kill you. </font>
Yes, many "natural", "organic" substances are very dangerous. My comments weren't intended to make a point, but to ask a question. Some friends were stationed in Saudi Arabia years ago with the military. They say it was impossible to seal their house from dust. It would collect noticeably every day. I imagine the air in desert areas is loaded with fine silica dust. I'm just curious if that's true or not...and if silicosis among the general population is more common.
OkieG
/ Sandblasting question #24
Another option is to get a sand blasting attachment for a high powered pressure washer. If you're doing paint and rust removal on large areas, it works great. No dust, you don't need a giant air compressor, and the attachment is relatively cheap (about $100 from Karcher). I've put all kinds of different sand through mine, and it's much less finicky than an air powered sand blaster - I even use sifted river sand from my creek.
/ Sandblasting question #25
<font color="blue"> get a sand blasting attachment for a high powered pressure washer. If you're doing paint and rust removal on large areas, it works great. No dust, </font>
I have a small conventional sand blaster and one like you describe. The reason I got the pressure washer (suction?) type was to eliminate airborne silica. You're right...there is no dust, but a thick mist is produced instead of a dust cloud. I suspect the mist is as heavily laden with silica particles as the dust is. Unless you know for sure it's safer, wear a mask or respirator either way!
By the way, you have a very interesting "bio". Good luck with your project!
OkieG
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
