Sandblasting Equipment
   / Sandblasting Equipment
Nobody told you that the CFM of air from the compressor wood overcome the box fans pretty quickly. You soon learned this. I have alot of flagstone walls that have been cleaned up using Black Beauty. Started and did not know where to stop. I hoped you rented the Kit on a weekend and that you enjoyed it as much as I did. Your project looks great.
Yeah, again, it makes me wonder if just renting the compressor and using my 100lbs sandblasting pot with a smaller tip would have been a bit easier to control media and dust with as you can only force so many CFM's through a 3/8" line, but obviously would have taken more time. The project wasn't as terrible as I originally thought, but definitely not what I "enjoy" doing with my weekends, lol. I attached a pic below of what I think I'm going to do with the wall with a stain or paint to break up the grey a bit. Let me know what you guys think.
   / Sandblasting Equipment #42
Hauln
if you can find some similar rock try it first on a loose stock/rock as stain or paint on one or two rocks per / sq yard may work OK but could look all wrong when done...
Mark
Hauln
Mark
That's probably a good idea. I have several loose limestone rocks outside which have a similar grey/blue hue. I haven't looked into what technique to use, probably a dry brush of some sort to keep from overwhelming any one color. The limestone should be a good test for different application techniques.
CONIBEAR EQ CO HYD SEED SPREADER (A60430)
CONIBEAR EQ CO HYD...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
John Deere 5100M (A53317)
John Deere 5100M...
