Sand blasting
/ Sand blasting #21
How do you use these personal units? Can you sweep up the media and use it again?
Yes you can - probably need to screen it though before re-use.
I think most materials become finer after a handful of uses, not a problem for many jobs but if you're doing really pitted, scaley rust new is better and quicker.
/ Sand blasting #22
I have never used sand. I think the primary concern is the threat of silicosis. I use Black Beauty, a slag product which comes in different grades. I have also used walnut shells when blasting softer materials where I didn't want to create a rough, pitted surface. I think sand may also be more susceptible to clumping from moisture.
Hi i'am out in oklahoma and new on this board..i'am looking for some slag for a drive way we live out in the country and have a quarter mile drive..saw your post on slag(black beauty)as you call it..know of anyone in Oklahoma that might have it or know where to find it?thanks!
/ Sand blasting #23
I have used sand and plastic media.
Sand removes rust better, but plastic media takes off paint better.
If you reuse the sand it works, but not as well the second or third time as the sharp corners of the sand get dull.
I think you can find sand by looking up sandblasting in the phone book.
Never sand blast aluminum.
/ Sand blasting #24
I bought mine at harbor freight years ago, the first thing that gave out was the chincey ball valve.
I was in the store a month or so after that and up in the front of the store I found this. Search results for: 'deadman' works so much better.
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A61572)
2018 Caterpillar...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
2017 KOMATSU D61PXI-24 CRAWLER DOZER (A64279)
2017 KOMATSU...
2025 Mini Excavator Rake Attachment (A61572)
2025 Mini...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
